Limp Turn signal lever
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I need to fix the turn signal lever on my '90 RS. When I bought it the signal lever was just hanging down(still attached to the hinge) but it doesnt click up or down. The high beams work and what not so Im wondering how I can fix this? I already have my steering wheel off since im installing a new one. Do I need to dig a little deeper into the column?
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Limp Turn signal lever
Not sure on an air bag column, but on a regular column you need to remove the lock plate. There is a very cheap tool to buy that makes it much easier. You compress the lock plate, remove a fussy little clip, and slide it off. You should be able to see what is wrong after that. There is a little metal arm that is supposed to connect the lever to the switch. It's held on with a phillips screw that may have come loose.
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
is the phillips head the same prob, when the hi beam stops clicking?\
Car: '90 RS
Engine: Vortec 350
OK, ill post back with results. My steering wheel is already off and I gotta get that tool form my friend again to pull off the air bag clock thing and then ill see whats up from there. Hopefully get to this by the end of the week.
Engine: that I like
MikkoV
Sep 9, 2015 04:25 PM
