all racing seat people need advice
Old Jan 31, 2008 | 09:36 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i was wondering how hard it is to put in racing seats. im getting scat seats from summit and was wondering how the sliders would be installed? they line up with old holes, or do i gotta drill new? thanks your help is apprecited
Old Jan 31, 2008 | 10:15 PM
BuiltZ28's Avatar
Re: all racing seat people need advice
Before my racing seat endeavor I had heard much talk about how you needed to make your own brackets or adapters and it actually seemed to require some mild fabrication.
However in my own experience I simply re-drilled the stock tracks to mate up with the new seats, works like a charm, best of luck with yours.
Old Feb 1, 2008 | 05:56 PM
Engine: 355
so you didnt use the sliders that came with the seats? or yo drill and attach the aftermarket slider to stock bracket? im cornfused
Old Feb 1, 2008 | 06:48 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
he means he used the stock track / slider mechanism .. and just re-drilled it to bolt the new seat to it ..
hope that helps ..
Old Feb 1, 2008 | 06:52 PM
Engine: 355
and by doing that i can just use the stock location ah ha i got it now.. how hards it to take track off? just line up where the new seat goes and drill holes and bolt seat to stock slider, then bolt to floor? lol im a dum mass
Old Feb 1, 2008 | 07:31 PM
Transmission: 5 spd
i dont know how hard it is to take the track off the stock seats ..
maybe just a few bolts or rivets .. ive never done it ..
but yea .. just bolt the "new" seat to the "stock" track
Old Feb 1, 2008 | 07:33 PM
Engine: 355
thank ya
Old Feb 2, 2008 | 06:14 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Just a suggestion. The first time I did a sport's street seat switch out, I lined up a buddy that had some metal fabrication knowledge. Sure enough, he know the right tools to use, kept me busy from standing around and just feeling overwhelmed, and did one little weld job to attatch an extra brace. 3 hours later we were driving down the road.
I've actually got a set of Recaro seats sitting in my garage. I'm planning of adapting them to the factory seat tracks so I can use the driver's power options.... So this is definitely one of those jobs where you need to line up a buddy to play job foreman. Will the new seats ever look so ultra cool when your done!!! Nobody will be able to make smart remarks about 'hillbilly transportation' after one of these modifications!! Best of Luck,, Nitro
Old Feb 2, 2008 | 08:47 PM
Engine: 355
how did you attach your seat belt loop? i dont want finagle em and ruin my seats
Old Feb 2, 2008 | 09:12 PM
Transmission: 5 spd
i got a good bit of metal fab / custom work ive done in the past ..
everything from making a cart for my mig welder, making a custom mount to suspend a radio in a 1985 f350 (theres a huge "empty" space behind the radio cover), and shaving door handles and mouldings off my friends pieces of rice .. i mean civics ..
actually .. i used to have a bagged toyota pickup (that i traded for my camaro, what dumba$$ that guy was) .. and i welded some extra toyota mr2 seats i have straight to the truck .. hahah ..
but if you can weld and can think of how to do something .. anything is possible .. especially when you want it perfect .. (i could care less if that toyota blew up, but that f350 radio mount was flawless )
oh .. and try not to catch the seat on fire with the sparks if you decide to weld it .. hahaha .. just a thought ..
Old Feb 3, 2008 | 02:15 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I had few different race seats in my third gens. I used the old brackets from the stock seats and just got steel brackets from home depot cut them and used as adapters to fit the seat. The Brackets held up great and you can virtualy use any set with the stock bracket.
Old Feb 3, 2008 | 11:10 AM
Engine: 355
hey im getting my new seats in two weeks. i was taking tracks of and you more then likely can use the power option!! im gna re route the wires to the front of the seat, and where the tracks line up in front im gna run a same piece of flexable sheetmetal from track to track... cut out for the power buttons that are on the side, and install and bolt down.... hiden power seat.. be **** huh
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
