Trunk Issue
Old Mar 6, 2008 | 11:02 AM
livewire195's Avatar
Trunk Issue
I recently changed my amps around; from the truck to under the seats. Now when I drive the trunk release consistently goes off, and I have no idea what to do.
Old Mar 7, 2008 | 06:27 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Trunk Issue
Sounds like you have an intermitant short between a power wire and the switch side of the hatch release wire. I would trace the wiring you moved with the amps and see if there is a place that they could come in contact.
Old Mar 8, 2008 | 09:46 AM
Re: Trunk Issue
The trunk issue is just one of the two others that occured when i re-did the wiring. The Shifter does not indicated Park, Reverse, Neutral, Over-Drive, Drive, 2, and 1. It is stuck between second and Drive. On top of that the ignition is locked, I have to pull it back and then push it forward to start the car. I think it has to do with the center console. But im clearly not sure
Vojtush31
Oct 11, 2015 01:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
Glowsock
Sep 5, 2015 07:48 PM
