Water in trunk Help
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Water in trunk Help
I have notice that there is water in the trunk well. I have no idea where it is coming from. Anyone have any idea to what I can do
Please
Help
Thanks in advanced
Please
Help
Thanks in advanced
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: Water in trunk Help
Check the weatherstrip first. Another spot to look is the black plastic pieces on the inside part of the hatch; where the glass meets the steel. I had one come loose and water made its way in. Last place I can think of is the seal between the hatch and the glass. I believe there is silicone, or urethane sealant. It may be best to have a friend hose down the car, while you sit in back and look for leaks. Good luck.
Engine: 350/350/LS1
k thanks.
i opened the hatch to put the t-tops in and there was water on the plastic where the hatch motor comes up. ill check and add more to the post later
Car: 1987 IROC-Z
Engine: 2002 LS1
Transmission: 2002 T56
Axle/Gears: fabricated 9" w/ 4.11 gears
hey i had the same problem for about a yeah. I replaced the weather stripping for the hatch and it still leaked. then i detached the spoiler panel from the glass on the hatch and resiliconed it and it still leaked, so finally i ran a bead of silicone along all the edges where the glass meets the spoiler panel panel and it hasn,t leaked ever since.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I was constantly getting water in my trunk, turned out to have holes in the rear wheel wells, and when it rained, the water made its way down in to the lower part of the trunk. Easy fix, some fiberglass hair, and resin.
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
how about water in the rear drivers passenger foot well. It looks like it's running under the B pillar on the drivers side. Anyone had that and how did you fix it?
Engine: 350/350/LS1
Ok found where it is coming from. The spot where the hatch glass meets the bottom part of the lid
What are the steps to fixing this? The water may also possibly be coming from the weatherstripping. But Im 99.9% shure it is not.
Please help thanks guys
Engine: 350/350/LS1
ha ha ha
Now seriously how do I go about sealing the leak
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Probably the best way is to pull it off, clean all the old sealant then reattach it using the correct sealant.
