Stain on Leather Seats
Old Apr 28, 2008 | 11:04 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Hey guys, I've got stains on my leather driver's seat from wearing a black leather jacket outside in the rain and then sitting in the seat driving. The black dye must have leaked off onto the seat and I can't get it off. Anyone have any tricks on how to get this cleaned up?
Old Apr 29, 2008 | 01:44 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: Stain on Leather Seats
i don't know, but i guess i won't be wearing my leather jacket in my car after the rain anymore.
Old Apr 29, 2008 | 02:36 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
The problem you have, is the stain from the coat is the exact same type of thing used to color the seats. So its going to be very hard to get the black stain off without removing the coloring as well.
Old Apr 29, 2008 | 02:41 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Have you tried any leather cleaner yet? If not I have some in the garage Jim that we can probly know it out with.
Kevin
Old Apr 29, 2008 | 03:19 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks, yeah we tried some leather cleaner it did nothing. My thoughts were the same as yours campin, the leather cleaner is probably basically cleaning the coloring that wore off on it too. I'm worried to use anything more abrasive might remove the seat color along with the stain. hmm
Old Apr 29, 2008 | 03:23 PM
campin1983's Avatar
The only thing I can think of, which is sort of last ditch effort, is to go ahead and use something strong to remove the stain, and then use a leather dye to try and fill in the spot, and match it as close as possible
Old Apr 29, 2008 | 03:26 PM
BronYrAur's Avatar
Engine: 305 TBI
well my only hold up on that is that it's not a "spot" per se, it's basically the entire back of the seat.
Old Apr 29, 2008 | 03:52 PM
campin1983's Avatar
No offense, but I'd get a new leather coat. I wore a reasonably inexpensive leather coat for years on leather seats, and I've never had this happen.
If the entire seat back is ruined, I might just give up and buy a new set of upholstery from hawks or some place like that. you can get just the cover, so that you don't have to replace the foam or the frame or anything.
Old Apr 30, 2008 | 09:43 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
A solution that should work for removing die stains is isopropyl alcohol. This product removes ink stains from leather and may be worth a shot on the die. You can get it at most pharmacies. Put some on a clean rag then dampen the area of the leather. Let it soak in for 10 to 15 minutes (apply more if it starts to evaporate). Then gently rub and lift off the stain. It should come right out, or at least improve a lot.
Later when done, treat the are with leather conditioner to replace the leather's natural oils and your done.
Some say hair spray works too, but I'd caution that approach. The active cleaning ingrediant in hair spray is isopropyl alcohol anyway and you don't want all the other possible damaging chemicals.
Good luck.
Old Apr 30, 2008 | 10:30 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Not to sound like a smart ***, but how about rain water?
Old Apr 30, 2008 | 04:26 PM
BronYrAur's Avatar
Engine: 305 TBI
Good luck.
Great idea, thanks for the tip, I'll give that a try and let ya all know how it works.
MrPackstin
Oct 25, 2017 08:09 PM
Eric-86sc
Feb 25, 2016 09:02 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
