Cluster swap
Old Apr 29, 2008 | 11:54 PM
denthar's Avatar
Car: !985 Chevy Camaro
Engine: 2.8L
Cluster swap
I have a 1985 Camaro and it didnt have a stock tack. i got a gauge cluster from a scrap camaro and it has a tack i was wondering if this would be difficult to install. i'm not really sure where to start.
Old Apr 30, 2008 | 12:10 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: Cluster swap
did the same thing to 1986z28owners daily driver the only things you should need are new temp sender and oil sender the tack worked fine in his with no mods.
luke
Old Apr 30, 2008 | 01:18 AM
denthar's Avatar
Engine: 2.8L
Re: Cluster swap
luke
how would i wire the tack? there is no existing tack.
Old Apr 30, 2008 | 05:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Cluster swap
Welcome to TGO. FYI: 82-89 clusters have mechanical speedos and are interchangeable V8 to V8 and so on gauge to gauge, idiot light to idiot light. 90-92 have electronic speedos and aren't interchangeable with the earlier years. Check the following link for info that may be helpful when swapping idiot light to gauge:
https://www.thirdgen.org/gauges
JamesC
Old Apr 30, 2008 | 08:17 AM
driver101's Avatar
Re: Cluster swap
never had to when i did
Old Apr 30, 2008 | 01:04 PM
denthar's Avatar
Engine: 2.8L
Re: Cluster swap
JamesC
i still dont know how to install the tack. my car had no tack, so now i need to intall my gauge cluster with a tack... i now know how to install everyting but the tack... and without that, there was really no point for my changing my gauge cl,uster, becasue thats why i went out and got a cluster with a tack. i know how to install a aftermarket tack... but this dosent look like an aftermarket one.
Old Apr 30, 2008 | 02:05 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: Cluster swap
If there is a white wire on one of your factory plugs behind the cluster then you are already wired for tach.
Old Apr 30, 2008 | 02:15 PM
JamesC's Avatar
Re: Cluster swap
Did you read the material in the link that I posted?
JamesC
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
