145 mph cluster / speedo
Old May 12, 2008 | 01:38 AM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Hi
I baught a 145 mph speedo and it has about 9000 more miles than mine and i wish to have the original amount of miles on it!! is it possible??
its a cable driven speedo!!
is it good if i connect to an electric motor with reverse or not? do the odometer go back?
any help will be appreciated
thanks
Lorry
Old May 13, 2008 | 07:56 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: 145 mph cluster / speedo
Do a search, the rollers are easy to replace if you have patience
Old May 13, 2008 | 09:24 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I just pulled the speedo out of the cluster, pulled off the little clip, and removed the odometer reel. Then just swapped my original odometer into the new speedo. Takes about 30 minutes to disassemble, swap, and reassemble.
Old May 14, 2008 | 06:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Several posts down in the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old May 18, 2008 | 01:57 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Use a pencil eraser end and roll the digits to wherever you need them
Old May 18, 2008 | 03:00 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
That won't work, at least on 82-90 gauges. The numbers are locked in place, probably to prevent tampering. I don't think it will work on any gauge cluster, but I have never tried it on the later models so I can't say for sure.
Old May 18, 2008 | 03:35 PM
JamesC's Avatar
Originally Posted by Titan85
The numbers are locked in place, probably to prevent tampering...
Certainly won't work on 82-89 mechanical clusters. I doubt that'll it'll work on the 90+ either as Titan suggests.
JamesC
Old May 18, 2008 | 05:56 PM
86FyrBrd's Avatar
Mine musta been broken then cause it worked. oh well. It was either my 86 Firebird or Trans Am, dont remember which one. Probobly the Trans Am.
Yup, was the T/A. I had the gauges out and made the dumb mistake of taking a needle off, I couldnt get them back just right so I bought another set. I set the milage as I said before and put the new ones in with white faces on it. Still worked accurately too.
Guess I was lucky.
Old May 18, 2008 | 06:59 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
It depends on what you mean by "work." The numbers can be rolled but the end result is that the first number will never line up correctly. It will always be slightly above or below the rest. It's one way you can tell a speedometer has been rolled.
Old Jun 6, 2008 | 04:05 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
today i received the cluster after shipping period and it was hard to roll the numbers on the odometer at first but after 10 mins playing i got in mind that every number you set you have to use some masking tape and put them in line and set the plates between the rolls parallel exactly to the desired milage numbers and as soon you set all the numbers there is a small plastic with squareish holes (yellow plastic) so it keeps your metal linings in line to put again in the plastic speedo carrier!!
after all this work double check everything and with some help with a driller in reverse motion instead of a drill put a small broken alankey and swith on and you can see if left over 3 or 4 mins driving the speedo that all the numbers are horizontally lined even!
if not dismantle again ,put again masking tape to those that are correctly even and relocate those that thay arent!
any help let me know because may be my english is not that good!!!
i am maltese guys!! and my avatar is my flag!!
cya
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
