spoiler
Old May 20, 2008 | 10:20 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
spoiler
i want to paint my car but my spoiler doesnt line up with the side ones.is the only way to adjust this from the inside the four bolts?one side is almost a half inch i am afraid if i move it that much it wont match up with the locking device
Old Jun 17, 2008 | 06:55 PM
RS305's Avatar
Car: 92 25th Anniversary RS
Engine: 305ci 5.0L V8
Re: spoiler
im currently having the same problem and i would also like to know if theres a way to fix it
Old Jun 17, 2008 | 07:08 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: spoiler
Yea, you should beable to change how it lines up with shims, (washers) I found a couple on mine
Old Jun 17, 2008 | 07:30 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: spoiler
There are 2 ways to line up the 3 spoilers pieces that I know of.
1. You can remove the rear deck area and reglue it on in the correct position. This was never a science from the factory.
2. I did this part just last week on my neighbors 89. We loosened the 3 bolts that hold the side spoiler pieces on and moved them back until they lined up with the hatch spoiler. The hatch spoiler does not have any play in the mounting holes so it is not adjustable. The entire rear hatch painted section was out of alignment so short of removing it and regluing it, we found the play in the side spoilers. It's almost a perfect fit now. Adjusting the entire glass hatch is not an option as his was perfectly aligned. The glued on painted area with the hatch spoiler was completely out of wack and we didn't want to mess with the glue process.
Old Jun 17, 2008 | 11:06 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: spoiler
I have heard that the actual hatch hinges play a part in this problem. I think they get loose so they let the hatch slide back. The fix (only read about, never tried it) is to loosen the hatch bolts holding the hatch to the car, then have someone hold the hatch up and push it toward the front of the car while you tighten the bolts back up.
I think its worth a shot seeing how it is much easier than the other fixes
Old Jun 18, 2008 | 10:17 AM
RS305's Avatar
Re: spoiler
the hatch on mine is aligned, the only problem im having is that the hatch spoiler sits too high on the right side. all of the hatch bolts are on and tight, so im assuming i need to readjust the side poiler somehow. i can see the bolts holding them in place, but i cant find a way to loosen them from the inside
Old Jun 22, 2008 | 07:48 AM
scottmoyer's Avatar
Re: spoiler
Two of the speed nuts are accessible by removing the rear plastics and exposing the inside of the rear 1/4s. The 3rd speed nut (on top) is harder to get at. You will need to rmove the taillight assembly. There is a hole in the body that allows access to that nut.
If the one side sits higher than the other, hae you checked the hatch bumper rests and adjusted up or down?
Old Jun 22, 2008 | 01:50 PM
RS305's Avatar
Re: spoiler
nope, what are those? (excuse me for being such a noob)
Old Jun 26, 2008 | 06:58 PM
scottmoyer's Avatar
Re: spoiler
The rubber stops on the bottom of the hatch. They are similar to the hood stops. The rear hatch rests on these and they touch the body just above the tailights in the corner of the rear hatch opening. You'll see the marks left by them near the corner seam. Just turn the side that sits high until the hatch rests level.
Old Jul 17, 2008 | 12:28 AM
HairHag's Avatar
Car: '88 Camaro
Engine: 305 TBI
Re: spoiler
This is the problem with mine - and why i quoted this. How hard is it to move the hatch back into place? This isn't a concern involving the spoiler, has i have the base spoiler on mine so no alignment problems there. But the hatch alignment is off enough that a heavy rain can leak through sometimes.
Old Jul 17, 2008 | 08:41 AM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
Re: spoiler
i was playing with mine the other day and couldnt believe how easy it was.all i did was lift the glass put a broom handle to hold it up and loosened the four 13mm nuts.had a friend push it in while i tightened it.there is a plate in there that only gives you so much adjustment.if you take your window out and drill the holes bigger you will have all the adjustment needed.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
F-body-fan
Nov 4, 2015 06:13 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
skip91
Sep 22, 2015 10:25 AM
