Steering column swap possible? also, weird noise from rear
Old May 22, 2008 | 09:02 PM
BlackFormula's Avatar
Car: 92 Camaro RS
Engine: 350 ci Carb
Transmission: 5speed
so ive got a loose tilt issue, it was missing one bolt, so i could only tighten two, now its loose again. looking at getting a column, but its out a vats car, my car has NO vats. isthis direct swap (i switch the ignition switches) going to work?
Weird noise: ive got a LG4 4 barrel in an 87 formula, every now and again i hear a weird noise from back by the gas tank area, almost sounds like a fuel pump...like WTf, its a carb motor, ive got a mechanical pump. any ideas here??
Old May 29, 2008 | 04:37 PM
Vanilla Sky's Avatar
Re: Steering column swap possible? also, weird noise from rear
I have the same issue in the rear with the sound. I haven't found the cause, and haven't had the money to fix it if I did. Sounds like a deep groaning, right?
Old May 30, 2008 | 09:46 AM
Car: 92 Camaro RS
Engine: 350 ci Carb
yea kind of. it only lasts a few seconds then its gone. i didnt drive or start the car for any reason yesterday, it was cleaning day. so then it did it again last night. i was like WTF!!!!!!! my car is possessed! i dont think its affecting the car, it does seem to run very RICH most of the time, and i do get a small hesitation (but i need a tune up too).....just...wierd...really
Old Jun 1, 2008 | 09:34 PM
sgtmac's Avatar
Car: 87 Fomula, bought new, October 86
Engine: 305 Quadrajet,
Axle/Gears: 9bolt now in, starting on body work
Your 87 Formula has an in tank fuel pump and filter even with the carbed 305, if its an original part in the car, it probably needs replaced. Several articles here on pulling the tank down and changing it out. I've just recently replaced the tank on my 87 Formula(wasn't leaking but it sure had a pile of crud in the bottom of it), new pump and filter-about $200 all together and an easy weekend's worth of work.
Old Jun 2, 2008 | 09:06 AM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
I wonder if locktite would hold those screws into place for ya.
Old Jun 2, 2008 | 09:16 AM
DCOWBOYS1975's Avatar
Car: 1986 Chevy Silverado
Engine: 350 Crate
Transmission: Turbo 400 w/ shift kit
Axle/Gears: dana60/corp14 4.10 gears
Locktite will work but do you know any trick to get that stupid ring back in?
Old Jun 2, 2008 | 10:44 AM
Car: 92 Camaro RS
Engine: 350 ci Carb
So what you're saying is that even though i have a fuel pump on my engine (which is all i should need for a carb motor), i have one in the tank for some reason???? theres no fuse or circuit breaker for it in the fuse panel or otherwise. rather than dropping the tank and fixing a fuel pump i dont need (filter is on the carb, no inline filter is present), id rather just snip the wirse for it so i dont have that noise, OR my rich condition...
Old Jun 2, 2008 | 10:45 AM
Car: 92 Camaro RS
Engine: 350 ci Carb
In my opinion, that ring is a p[ain in the ***.....locktite will work, i've got a column comming thats non tilt, i wont have to worry about it anymore :-) problem is, its out of a 5 speed car, so im not sure how all that is going to hook up with my automatic car..
Old Jun 2, 2008 | 10:48 AM
Engine: 350 Crate
I did not know that mattered as far as the column goes.
Old Jun 2, 2008 | 06:06 PM
sgtmac's Avatar
I believe that Pontiac went to an in tank pump to solve a vapor lock problem. The in tank filter on my car was just about totally plugged when I took it out, it was the original one since October 86 when I bought the car new. You may want to drop the tank for a serious cleaning anyway.
Anyway, 87 Formula's rule!
Old Jun 18, 2008 | 09:04 AM
Car: 92 Camaro RS
Engine: 350 ci Carb
lol hmmm i've never thought they woulda put a pump in a carb fuel tank, but i guess its possible. 87 formula's do rule, last year for the lg4 :-)
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Bull86
Aug 10, 2015 05:43 PM
