power door lock problem
Old Jul 12, 2008 | 12:33 AM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
all my door lock acuators work. except when i hit the button to lock the door it pulls in not enough to engage the lock but it trys. and when i lock it manually and push the unlock button it unlocks fine???
Old Jul 12, 2008 | 01:20 AM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Re: power door lock problem
HA! Mine does that too. It has done it for years.
It will not unlock or lock the passenger's side door unless you hold the powerlock button down a few seconds or push it a few times. Let me know what you find out. It's annoying but has never been that annoying that I ever cared too much to do anything about it.
Old Jul 12, 2008 | 02:23 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Everything works fine, except your car is old!...Mine did that when I first got it. I had to keep pushing the lock button about 3 times before it would like all the way. I thought it was my door lock actuator, but then I kept reading some posts and decided to SATURATE all the locking mechanisms in the door with WD-40 and now it works great! I lifted up the boot on the actuator soaked some WD-40 in there too. That should get them working again...good luck!
Old Jul 12, 2008 | 06:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep. Common fix to a common problem (though cleaning the accumulated crud from the tracks etc. might be a good idea before lubbing).
JamesC
Old Jul 12, 2008 | 10:23 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Mine did the same thing, I sprayed all of the mechanisms with PB Blaster and now they move with no problem. They even have that new "clunk" sound now.
Old Jul 12, 2008 | 02:40 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Same here. Been doing it on the passenger door for over a year now, but only got annoying after I installed the keyless entry. Spent about 30 seconds spraying a lube on the mechanisms and they both fully engage and dis-engage. You can even do it without taking off the door panel. Roll the window all the way down, and look in from the top. At the latch end of the door are most of the pieces you need to get. If you decide to spray the actuator too, you will need to take off the door panel.
Old Jul 12, 2008 | 02:57 PM
Engine: 350TPI
let me tell you what!! i will try not to take that panel off. i put all new door panels from classic industrys and push in clips. and they do nothing but destroy themselves and the doors cardboard panels. very stupid design by gm. but i appreciate everybodys in but im gonna try and get this done today
Old Jul 12, 2008 | 03:07 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
Yeah mine did the same thing after I used PB Blaster. Hard part is getting the
door trim panel off and the plastic covering. But it works like new now!
Old Jul 12, 2008 | 04:11 PM
Engine: 350TPI
i just remembered they make a door panel clip tool. im going to buy that and oil up everything real nice.
Old Jul 12, 2008 | 09:02 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Does it have a slot to get behind the clip so you can pry the clip away from the door?
Old Jul 12, 2008 | 09:08 PM
Engine: 350TPI
yes it has a v shaped slot to get under the ribs of the clip and pull it out
Old Jul 13, 2008 | 07:32 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Actually that V shaped slot is for installation. You put one side of the V inside the hole and rotate it. On some clips there's 2 rings of plastic that you would insert the tool between to pry it out.
On others, there's only one ring, that you simply need to get under the one ring to lift it out.
Old Jul 13, 2008 | 06:38 PM
Engine: 350TPI
so i bought that tool today 7bucks from advance auto parts.( i really recommend it it made everything so easy to remove) i saturated all the locking mechanisms and all the bar connections. also saturated the actuator arm and the plastic clips on the door frame with jig a loo. then i went back through and saturated everything with white lithium grease so i dont have to go back in there anytime soon. good as new locks working great and like mentioned has that new car clunk noise
Old Jul 13, 2008 | 07:13 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Did you do the window tracks as well? My windows still seem to go up slowly. I'll probably have to replace the motors.
Old Jul 13, 2008 | 09:07 PM
Engine: 350TPI
yes i did the tracks to and they still go up slow. even with new motors they still go up slow. i just think it was the way the car was designed maybe.
Old Jul 13, 2008 | 10:08 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Heh I just shot some white lithium grease in there and they freed up just fine.
Old Jul 13, 2008 | 11:29 PM
Engine: 350TPI
only problem is it really gets your windows all nasty. but simple thing to fix glass cleaner and rag
Old Jul 14, 2008 | 03:11 AM
HCR13's Avatar
Car: 1987 Trans Am
haha good deal!
Old Jul 14, 2008 | 04:14 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Mine have been doing the same thing think ill try it out today since you guys have had sucess at it. Thought i might have to replace the actuators.
Old Jul 14, 2008 | 05:18 AM
Steveh4263's Avatar
Engine: 5.7 LTR
I just buy paper towels and glass cleaner at the Dollar Tree. Everything is $1 Dollar there. But yeah that Lithium Grease makes for a nasty mess.
Old Jul 14, 2008 | 09:42 AM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
If you took the door panel off then you just shoot where you have to shoot it and don't make to much of a mess. but yea I Thought it was my actuator motor and then in reality it was all of the moving parts.
Old Jul 14, 2008 | 11:16 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
the windows are designed to move slowly.... the volts get knocked down going the the window motor.. I have a set of doors I sold and I had to pull the lock cylinders out,, so I cut one of the plugs and stripped the wire ends.... used a 12 volt drill battery to give em power so I could get to the locks. With a 12v power supply they fly up.... 2xs faster than they did on the car.
Old Jul 16, 2008 | 06:37 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
I tried this the other day I only had some wd 40 but it got the driver side workn great. However the pass side is still lacking enough to fully engage the lock, so im gonna try some lithium grease and if that doesnt work i gusee ill replace the actuator. Great tip though.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
