How do I tighten a steering column on an 89 firebird?
Old Jul 30, 2008 | 07:41 PM
ChiefLongWood's Avatar
Car: 1989 Firebird
Engine: V6
Hey guys im selling my car tomorrow but the buyer insists that i fix the loose steering column before he buys it. To tell you the truth I dont know what is really loose in there but if you grab the steering wheel you can take it and rotate the whole thing holding on to it. I went out today and thought I could fix it so I took of the front pad thing with the horn wires and took off a nut that I though held the thing together turns out it did nothing and I cant get it off. How am I gonna tighten it up? Any help would be great! Thanks
Old Jul 31, 2008 | 11:20 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
Re: How do I tighten a steering column on an 89 firebird?
There's a tech article telling you exactly how to do this. Steering Column Fix
Read up on the article. You'll need a torx set and a specialty tool, the steering tilt pin remover or something like that. I'm pretty sure the local parts store might have one, or Snap-On's is 15 bucks online.
Old Aug 4, 2008 | 10:15 PM
yfirebird86's Avatar
Just did this yesterday. Good info at --> https://www.thirdgen.org/forums/faq-...eels-like.html
Info included how to use a 8-32 UNC bolt to pull the pin, negating the need for the pin pulling tool. Worked great.
Old Aug 4, 2008 | 10:31 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
If you've never done this before and your in a crunch to sell the car in a certain time frame I would just knock $100 off the total price before I broke the column open.
You can do some damage in there if you don't know what your doing. Plus you'll need 2-3 specialized tools get to the bolts.
EDIT: I need to start looking at dates, the original poster created this thread on 7/30/2008......did you sell your car? How did it work out?
Old Aug 4, 2008 | 10:47 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Dude this is an UGLY job if it goes bad. My tilt pins were in so tight all they did was bend bolts when I tried the reccomended bolt and socket method. Then I borrowed a snap on tilt pin remover from a local mechanic and that broke, but they way it was designed it broke off into the pin, leaving NO WAY to remove the pin. I went to the junkyard and paid 75 bucks for another column, and this one has loosened as well.
I kept the old one, think I'm going to try and get in there with a welding rod and just tack those suckers tight.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
