4th gen dash swap
Old Oct 6, 2010 | 12:49 PM
  #201
box_chevy's Avatar
Re: 4th gen dash swap
I've got other ideas too. Would it work to install the 4th gen door panels with the controls and run the window switch wiring and the hatch release all the way to the pigtails in the center console? And the switches themselves are different, connector-wise right? And the hatch release is too? Would you have to splice the passenger window wiring to allow the passenger to roll their window down? Has anyone installed the interior fading light feature with success or is that impossible? A nice luxury but definitely not neccessary. Thanks in advance.
Old Oct 8, 2010 | 05:32 PM
  #202
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Originally Posted by box_chevy
[B]Let's start this up again. Will a 97 cluster work in a 98-up dash?
Yes as long as you use a T/A dash or the 97-up camaro dash.
I've read that the 97's are the way to go as far as compatability.
93-97 clusters will all work. Its 98-02 clusters that are not 100% compatible.
This car shoud have vss but i'm not sure. It's not cable driven so it should be. Will the tach/spedometer work or will i need the converter?
it will wire up and work fine no converters needed. 90-92 Camaro's have electronic speedo's and the tach is not an issue though you may experiance a "bounce".
Has anyone attempted to install the old HVAC controls back onto the new dash or is that a stupid question?
This is the best way to go to date. Mount your factory HVAC control in the 4thgen dash.
Is there even an older style cluster with the digital odometer or have I lost my mind? If there isn't, I still want the older cluster.
I have heard not all 97s had digital odometers. Why bother? you will be hard pressed to even find one. Go with the analog odometer and make your life easier.
Old Oct 8, 2010 | 05:37 PM
  #203
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
[B]I've got other ideas too. Would it work to install the 4th gen door panels with the controls and run the window switch wiring and the hatch release all the way to the pigtails in the center console?
Yes that will work. 4thgen panels do not fit properly you are seeing 'selective' shots users have chosen to post. You would be happier with factory door panels or a custom style. 4thgen panels= your doors wont close properly and they look like they are butchered in in terms of fit and finish. Everything is tight and squished.
Yes but easily wire up anyway.
Yes or you can wire the factory 3rdgen wiring to the double drivers side 4thgen switch. Adding the passenger side 3rd switch requires extra wiring work.
Old Oct 9, 2010 | 09:13 AM
  #204
box_chevy's Avatar
Thanks to all that answered my questions. I will post in detail pics of the swap so that other newbies like myself don't feel like they're going off the deep end. Hopefully Soon!!!
Old Oct 10, 2010 | 11:32 AM
  #205
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
it is extremely difficult to get everything ironed out for the best fit possible, but with the effort and ones skill level, you can make them look and fit very good.
you post pictures of angles you want to see and ill try to duplicate those with my pics.
make it happen today. im going to wash the car and put the cover back on and it will be next week before id mess with it again.
i have "the gap" at the bottom front of my door panel, but only a purist would say they dont fit in this area.
everywhere else is great.......
you must have had bad luck fitting your panels, or really ****.
Old Oct 10, 2010 | 12:55 PM
  #206
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
I think the fading light feature is controled by the 4th gen BCM 3rd gens aint got em.
Old Oct 11, 2010 | 08:16 AM
  #207
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Everyone's idea of looking good is different I suppose. I don't think it takes much skill at all to cut and chop these in anyone who does there own work should be able to do it. Personally that didn't fly for me in the end. It felt like one big butcher job for a cavalier like door panel.
Post all area's top bottom, sit in the car and close the door then get a pic of where the door panel meets the dash. Then get a pic from the top par corner looking down. Simply take pics from all angles.
I am very picky. I like things to look as stock as possible.Shroom posted pics of the best way possible to get a 4thgen looking panel in these cars who also tried to "massage" the factory ones in place.
The panels where never designed for a 3rdgen and to try and say they fit near 100% perfect without any type of glassing or reworking is a little far fetched. But then again everyone has different ideas of what close to stock is. I guess I am a "purist" as you say.
Old Oct 11, 2010 | 10:38 AM
  #208
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Anyone do a LT1 dash? I swapped an LS1 dash into my LT1 4th gen car so I still have the factory dash in my garage. Since my dash pad on my 91 is cracked, considering this as a cheap alternative, unless i come across a stock third gen dash pad then I will sell the LT1 dash
Old Oct 11, 2010 | 09:28 PM
  #209
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
ill get the most ugly pics i can take sat. ill have them up sometime sat or sunday.
very busy week for me.
Old Nov 8, 2010 | 06:58 PM
  #210
92redhotcamaro's Avatar
what wireing harness do you use the original one in the car or do you take one from the 4th gen with the dash?
Old Dec 22, 2010 | 06:26 PM
  #211
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
subscribing
Old Dec 23, 2010 | 01:08 PM
  #212
Guest
Guest
Posts: n/a
I cannot believe th work people can do with these cars. It's amazing i would own a camaro forever a third gen if it had 4th gen interior everything. It would look so updated some people think value would drop i think it whould sky rocket.
Old Jan 30, 2011 | 02:16 PM
  #213
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
https://www.thirdgen.org/forums/inte...r-ducting.html
Complete walkthru for installing the 4th gen heater ducting into the 3rd gen.
I also grafted a complete 1994 harness into my 1983 Z/28, deleting the VATS, Passkey, SIR circuit, ABS system, and all emissions wiring. I do have working power door locks, power windows, interior lighting, dash lights, gauges, fully functional climate controls, retained accessory power, and power seats. I grafted in my modified 1985 Corvette TPI harness (injectors, O2 sensor, throttle position sensor, air intake temp, coolant temp, and tach only), and added in 24 pin computer connectors in strategic locations to allow modular removal of different parts of the harness. I routed my wiring thru the fenders, hidden under the heater box on the passenger side of the firewall, and kept the 1994 underhood relay/fuse box and have it mounted ahead of the windshield washer tank.
Old Apr 21, 2011 | 08:27 PM
  #214
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
Originally Posted by TPI TERR
currently workin on dash swap . cluster is workin but i dont have the hot and igntion hooked up so would this cause my turn signals not to work yet?
also i have my headlight and parkin lights workin with the 4th gen switch
does anyone have the schematics for the small bezel lighting "white letters" to light up . ? i have my cluster lighten up right now
What year dash did u use for you
Old Apr 22, 2011 | 12:17 AM
  #215
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
02 everything has been working properly
Old Apr 5, 2012 | 09:44 AM
  #216
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I came across a free 1997 Z28 dash las night I'm going to put it in my car.
Will having an LSx swap make the dash wiring any different? Also what did you guys do with the window switches on cars you left the stock door panels in? On a 4th gen the switches are on the door not the center console.
Old Apr 5, 2012 | 10:51 AM
  #217
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Ashtray brother.. perfect fit for window switches
Old Apr 5, 2012 | 11:15 AM
  #218
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I didn't get a response in another thread, so I'll ask here:
Any of you dash swappers running the stock 3rd gen ECM (1227165 or 1227730 for a lot of your V8s)? If so, where did you mount it?
Old Apr 5, 2012 | 11:51 AM
  #219
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
it would only be different if you're using the 98+ instrument cluster, since the gauge info for those comes from the serial bus. I opted to stick with the "LT1" cluster to run analog gauges just like factory 3rd gen
Old Apr 5, 2012 | 12:57 PM
  #220
BlueZee28's Avatar
So I should be able to snip off the C100 bulk connector from the dash on the firewall and solder the corresponding wires on the new dash into the junction where they were on the stock dash?
Oh and another question I had was, what will I need to do with VAtS to ensure the car starts when I'm done
Old Apr 5, 2012 | 06:49 PM
  #221
92CamaroKyle's Avatar
Car: 1992 Camaro RS
Engine: LS 1
Axle/Gears: 10 Bolt 2:83
Is your vats turned off in the ecm? I wired the green ground wire from the start relay to a hidden switch and left it disconnected from the ecm. Works just like vats, wont crank until I flip the switch.
Old Apr 5, 2012 | 08:42 PM
  #222
BlueZee28's Avatar
Yea I believe it is turned off in the ECM, but the 3rd gen aspect of the system still functions with the chip in the key and the box behind the dash.
Old Aug 11, 2012 | 09:40 PM
  #223
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
never updated this thread but only issue im running into right now is not enough air flow through the vents. i cut 4th gen portion to match the oem 3rd gen but its not functioning how it suppose to. 4th gen ventilation must be different. any leads? if not im looking into heater air duct or something similar.
oh and i did my door panels a while back yes i know it has the usual crack up top
Old Aug 13, 2012 | 06:19 AM
  #224
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
That's awesome, any write up on to do those?
Old Aug 13, 2012 | 06:34 PM
  #225
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Unfortunately I don't*, I did use a torch to make this an easier install . Alot of trimming on the door panel it's self with no too many major cuts on the door sheetmetal besides the Interior door handle area
Old Aug 24, 2012 | 04:20 AM
  #226
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
awesome job on the door panels, i have a set out of a 2000 SS hanging on my garage wall but havent got the ***** to go all out on it yet...only NICE set of black 3rd gen panels i can find is 300 bucks. too rich for my blood.
Old Aug 24, 2012 | 07:14 AM
  #227
haisud's Avatar
Pics or it didnt happened
Old Aug 28, 2012 | 10:25 AM
  #228
ligerzero5621's Avatar
Car: '76 LT, '87 IROC
Congrats on all the hard work man, it does really update the look on our 3rd gens a whole lot, but then again its a classic/muscle car and you are gonna get people that complain saying that its meant to look older like it used too.... oh well, my first car was a 95 Z28 and the interior fitted me so perfect and it was real comfortable, and I have a 76 Camaro and my 87 Iroc, both cars have 4th gen seats in them and i think those are the best mods out of 100 ive done lol.
Ill be keeping an eye on your work with your 3rd gen so i can see what all 4th gen interior i can do myself also lol,
good job man! and dont forget, we wana see pics after pics after pics!!!
Old Oct 18, 2012 | 07:31 PM
  #229
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
very busy week for me.10-12-2010, 02:28 AM
Its 2012 going on 2013 still no time?
The "selective" shots of 4th gen panels installed continues!
Old Oct 18, 2012 | 07:37 PM
  #230
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Well i finally have a complete interior and feel comfortable posting pics of mine
Old Oct 18, 2012 | 07:43 PM
  #231
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Come to so cal ill let u observe my door panels and full dash swap.
Bring ur car as well so I can give my personal opinion . It's 2012 you have a new coat of paint on your car yet ?
Old Oct 18, 2012 | 08:08 PM
  #232
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Why would I come to "so cal" for anything? I don't need to see a "full dash swap" been there done that. Just saying going on 2013 and still no clear shots. I wonder why.. And hey now! A new coat of paint takes far more skill then a 4thgen dash swap
Old Nov 12, 2012 | 09:55 PM
  #233
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
i plan on doing this swap myself... good information guys
Old Feb 11, 2013 | 01:47 PM
  #234
2speedlee_SA's Avatar
Car: 90 RS
Engine: LSX
Axle/Gears: 3:73
Im new to the site, have already started this swap, have a LS dash and console I will be starting. The dash I have was already mounted in another 3rd gen, So I know exactly how to mount it with no problems but this wiring is killing me. I dont care about the heating, just need my head,brake lights to turn on and for car to start. Also, is the steering column wiring connected to the dash?
Old Feb 14, 2013 | 06:23 PM
  #235
Engine: 2.7L V6
Axle/Gears: 4.41
Looking for someone who did the 93-97 Camaro swap...
What is the easiest way to get the spacer plate (between the upper part of the dash and the windshield) out of the donor? If I haven't already said, the car that donated my dash was in a front end crash, the windshield was destroyed, and so was the plate. I know of another yard that has a couple Camaros (at least they used to the last time I was there) that I can get the plate from, but I don't want to destroy it until I have to cut it to size...
Anyone?
Old Feb 15, 2013 | 02:04 AM
  #236
Car: 90 RS
Engine: LSX
Axle/Gears: 3:73
Use cardboard and make a stencil then cut the dash pad to size
Anyone?
Old Feb 15, 2013 | 02:08 AM
  #237
Car: 90 RS
Engine: LSX
Axle/Gears: 3:73
Sorry, it's just held on with clips, should just pop off, mine is from 02 but I'd think its the same
Old Feb 15, 2013 | 12:49 PM
  #238
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
should.....\
if its cold take a torch or a heat gun and a generator, LOL. if its warm out it will come out pretty easy.
if its cold temps or been baking in the sun for months, ive had them crack in half, and also break(and leave a white line) around where the clips are. some of them are reallllly holding it on. the hard ones are right around the hump in the instrument cluster. i think there are two.
i dont want to scare you, just inform you.
find a broken one in the yard and see if they will give it to you. i used a cracked one to make a template and transferred it onto my new one.
Old Sep 28, 2016 | 09:16 PM
  #239
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I really could use some help I have to use a gauge cluster from a 93-97 firebird because I'm not using a LS but some of the 97 firebird odometers are analog and some are digital does it matter?
Old Oct 5, 2016 | 03:52 PM
  #240
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
No, it doesn't matter as long as you have everything wired correctly. Before I was finally able to get my hands on a 97 Z cluster I used an analog cluster from a V6 and a V8 93-97 bird. Of course the tach of the V6 was off but both of the speedos worked fine along with the odometers and trips.
Old Oct 5, 2016 | 04:48 PM
  #241
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
So the digital Odometer from a 93-97 is fine? Doesn't require anything extra?
Jorlain
Aug 24, 2022 05:11 PM
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
