Where did you buy you A-Pillar Pod??
Old Oct 17, 2008 | 01:53 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Hello, I want to get a t-top A-pillar dual gauge pod, the whole a-pillar not just a screw on pod.
Where did you guys get yours and how was the finish on the plastic? was it the same texture as original? Also any fitment issue? I did search on here and most said it was a 100% direct fit.
I found this one http://www.yearone.com/serverfiles/f...?hid=P26AL7345 , looks like a good deal. Anybody using YearOnes pillar?
More searching yielded this http://www.speedhut.com/product_deta...NUMBER-635.htm Anyone have that one?
Old Oct 17, 2008 | 03:02 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Where did you buy you A-Pillar Pod??
I purchased a triple pod for my t-top IROC to fill with Auto Meter's. Not too happy with it as it appears that it'll end up looking hacked or with a sad seam line showing. A better design would be a molding that has the pod formed into it without seams. Just my .02
Old Oct 17, 2008 | 05:37 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Was that the full pillar? Or was it just the part about the size of 3 gauges to fit in? What brand was the Pod? you mentioned Autometer gauges i think.
Old Oct 17, 2008 | 11:55 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
summit sells the whole pillar pre molded in single, dual, and triple gauge pods
Old Oct 23, 2008 | 01:55 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I have a triple gauge pod from Autometer but I honestly believe the gauge pods sit too low on the pillar since the bottom pod sits directly on the dashpad.... The finish is alright, not stock but not bad... I got mine off ebay for like $10...
Old Oct 29, 2008 | 05:46 PM
Darth Satanis's Avatar
Car: 86 Firebird
Engine: Buick 3.8 V6 Turbo
Transmission: 200r4
Axle/Gears: 3.42's
I ordered several for people through Checker Auto Parts where I used to work.
Old Oct 29, 2008 | 05:51 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Is that the whole pillar? or just a screw on piece?
Old Oct 29, 2008 | 10:34 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I havent seen a full pillar for a t-top... Part # pod 12203 looks pretty good too. I wonder how well it fits....
Old Nov 2, 2008 | 08:19 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
I found the same problem. I bought a 3-pod one but my dash sits about 1/4" high I suppose because it did not fit untill I took the dash pad off. Stupid how they did that, there is no tollerance. anybody try the 2-pod? I hope the bottom one in that is higher than the bottom one in the 3-pod.
Old Nov 3, 2008 | 01:59 AM
HCR13's Avatar
Car: 1987 Trans Am
mine is a full pillar mold and I have t-tops...
Old Nov 9, 2008 | 09:22 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
the dual pod "full" a-pillar from autometer also sits directly on the dashpad. I am returning it and going another route, its just that bad of a design.
Old Nov 10, 2008 | 03:21 PM
Dennis-Z28's Avatar
Well that solves that idea of mine. Why would Autometer do that? Weird.
Anybody have one from another manufacturer that can comment on how much space is between the bottom 'pod' and the top of the dash pad?
Old Nov 11, 2008 | 12:38 AM
HCR13's Avatar
Car: 1987 Trans Am
I think Stephen has a custom one made of fiberglass...
Old Nov 11, 2008 | 01:12 AM
Stephen's Avatar
Car: 87 GTA
Why do I keep finding posts referring to me? A friend of mine made these, I believe by using those add-on pods molded on to a stock pillar piece.
Old Nov 11, 2008 | 01:49 PM
HCR13's Avatar
Car: 1987 Trans Am
because you're just bada$$ like that!
Old Nov 11, 2008 | 07:31 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
you can get a full pillar pod 3 hole that are 2inch at jegs scroll down until you see GM
here is the link http://www.jegs.com/p/Auto+Meter/752285/10002/-1
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
tmellott89
Oct 14, 2015 02:06 PM
loud91rs
Oct 5, 2015 10:05 PM
