Column problems
Old Nov 12, 2008 | 03:51 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Column problems
I swapped my steering column for a tilt column and now my wipers dont work. I checked everything as I can see. I just wanted to know if anyone else had the same problems and what was the remedy.
Old Nov 12, 2008 | 05:58 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Column problems
Did you plug back in the harness that comes from the turn signal lever? It's separate from the column harness.
Old Nov 15, 2008 | 10:35 PM
6SIX6's Avatar
Car: 89 IROC
Re: Column problems
I will have to check again as Im not too sure as when I took it out it was a couple weeks before I put it back in. I might have missed it. If I didnt plug it in would it effect anything else???
Old Nov 16, 2008 | 01:48 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Column problems
Did your old column have intermittent wiper control? Your new column should definately have intermittent wipers as the options usually came together. If the wiper switches are different you will have to swap the control board. (Located inside the wiper motor cover in the engine compartment)
Good luck!
Old Nov 16, 2008 | 07:06 AM
6SIX6's Avatar
Car: 89 IROC
Re: Column problems
Good luck!
I dont think it has that option but I will check it out. Would it be easier to replace the wiper motor than the board??
Out-Cast
Mar 22, 2019 09:39 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
