'82 Z28 guages in '91 RS
Old Nov 24, 2008 | 04:54 PM
chops1sc's Avatar
Car: 2011 Silverado LTZ, 91 Camaro RS
Engine: 5.3L (LTZ), 3.1L (RS)
I have a 91 RS V6 (going to be swapping for V8 soon) and my donor car is an 84 Z28. I know the tach in a V6 will not work with a V8, I was wondering if anyone has tried using the tach from an earlier model to a newer one? My shop time is limited and I have not had the chance to remove the cluster from my 91 yet. I was really just wanting to know if I need to start looking for a 91-92 V8 tach or if the 84 would work. Thanks!
Old Nov 24, 2008 | 05:20 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: '82 Z28 guages in '91 RS
I believe the '91 uses an electric speedo and the '84 uses a mechanical speedo, so if you wan't to swap all the gauges that might be an issue. I have a '91 parts car with gauges... I don't know if they're v8 gauges or not. Is there an easy way to tell the difference?
Old Nov 24, 2008 | 05:22 PM
chops1sc's Avatar
Well I just want to change the tach, not the whole cluster. I guess you could find out what engine was in your parts car.
Old Nov 24, 2008 | 05:24 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
yeah maybe i'll check the VIN.
Old Nov 26, 2008 | 11:11 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The gauges will not swap over.... They are not compatable. Save your self the time / effort and try to find a replacement tach or cluster from a 90-92 car instead.
Old Nov 26, 2008 | 12:43 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
He's right the 82-89 cluster is totally different than the 90-92. You can't just swap the tach. I don't know if the dash is different but I don't like the 90-92 yellow guages so I'd try a full swap but that may not be possible...???
Old Nov 26, 2008 | 04:22 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
the entire shape of the dash, instrument cluster, and guages themselves changed for the 1990 model year, so even just the tachometer itself can not be swapped from an 84 cluster to a 91 cluster.
Old Nov 26, 2008 | 09:33 PM
chops1sc's Avatar
Thanks guys, I finally got out to the shop to do some work on the donor car. Also I indeed realized the dash components are different. I read where the resistor can be changed for it to work on a V8, has anyone tried this? I mean it's worth a try if I end up with a V8 tach anyway right?
junior419
Apr 7, 2025 11:35 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
blackz281le
Jan 11, 2016 07:51 AM
andy74
Sep 3, 2015 08:41 AM
