customizing deluxe door panels
Old Nov 25, 2008 | 09:32 PM
racerx520's Avatar
anyone know how to do something like this?
https://www.thirdgen.org/forums/inte...ht=door+panels
because i am going to try to get new deluxe door panels for my car and customize them to kinda have a foam flame coming up them, i saw it on the old g&t fiberglass page, but now that i recently looked there i havent been able to find the pictures.
and i want to try to do this, but i also dont want to waste materials by trying to figure it out on my own
Old Nov 26, 2008 | 08:10 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: customizing deluxe door panels
it looks like it is all described in the thread. he used an 1/8" plywood board to create the insert. The "WS6" was also cut out of 1/8" plywood and glued to the board. He then got a sheet of vinyl (it appears to be vinyl) and adhered it to the backing board. I would use permatex heavy duty carpet and trim adhesive for that part. I've used it on my t-top headliner and it worked great. He probably adhered the wood board right to the fiberboard door panel too, with a couple of holes in it to get some extra mechanical bond by allowing the adhesive to seep through the hole
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
