How do I remove these interior pieces?
Old Nov 26, 2008 | 07:04 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
I'm taking the interior out of my car and I am stuck on 2 bolts. The first bolt is holding those black pegs sticking out that hold the rear seats. (Fold your seats down, those stupid black pegs!)
The other which looks similar is holding the seat belt retainers down.
How do I take out the seat belt brackets out?
Old Nov 26, 2008 | 07:22 PM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
Re: How do I remove these interior pieces?
Is it just a bolt with a star head? if so you need to get the right tools so as not to strip it out. Thats the piece I am thinking of.
Old Nov 26, 2008 | 07:25 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
That stupid piece requires a tool called a torx bit. IIRC,the size is a t-50.
Old Nov 26, 2008 | 07:27 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Yes it does look like a star.
Old Nov 26, 2008 | 07:44 PM
like I said,you need a tool called a torx bit.All auto parts stores sell them.
I believe the size is t-50 but,not totally sure.It could be a t-45
Old Nov 26, 2008 | 07:52 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
thanks...this will remove the black bolts and the bolts for the seat belt retractors?
Old Nov 30, 2008 | 11:05 PM
camarod24's Avatar
Car: 1986 Camaro Iroc
If what you are saying is what I am thinking of (where the seatbelts are bolted in at the top) then it should be another torx bit maybe even the same as the one for the black pegs there will be two of them holding the seatbelts in and to get to them you have to pull down the headliner. :-(
Old Dec 2, 2008 | 10:49 AM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
you are working on a car and dont know what a torx bit is? Ya serious? lol.
go get a set of torx sockets from auto zone or something... has pretty much any size you will need. and yes im pretty sure they are the same size bolt for the seat belt as wellas the striker bolt for the rear seat
Old Dec 2, 2008 | 12:05 PM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
If u are doing ANY kind of work on these cars, torx bits are a must
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
