Difference in sun visors
Old Dec 15, 2008 | 01:38 PM
thekevin's Avatar
Car: 1985 Z28
Axle/Gears: 3.23 open
is there a difference in the visors on a hardtop and t-top car, are they interchangeable at all.
Old Dec 15, 2008 | 01:58 PM
Stephen's Avatar
Car: 87 GTA
Re: Difference in sun visors
They are perfectly interchangeable, but the T-top ones are smaller.
Buddy of mine put my spare hard top ones in his T-top car.
Old Dec 15, 2008 | 02:28 PM
thekevin's Avatar
Car: 1985 Z28
i have a t-top car and mine are trashed, i found a set of hardtop visors just didnt know if they would work.
Old Dec 15, 2008 | 03:02 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Only difference Ive noticed is that the T Top visors are curved while the hardtop visors are flat
Old Dec 16, 2008 | 12:18 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
They ARE different. Specifically both the curvature of the visor (as already mentioned). But more importantly, the mount is also different and not compatible. The t-top cars and 'verts share the sunvisors. Coupes are different.
Lon
Old Dec 16, 2008 | 12:23 AM
Stephen's Avatar
Car: 87 GTA
If the mounts are different....Can the flat panels be swapped, onto the different mounts? I know my hardtop ones went into a t-top car. Dunno, yet, if he just swapped out the panel or the mounts too. I'll hafta ask him.
Old Dec 16, 2008 | 01:08 AM
lonsal's Avatar
Yes. Just loosen the screw and slide it off the pin.
Lon
Old Dec 16, 2008 | 08:27 AM
thekevin's Avatar
Car: 1985 Z28
sounds like i need to just need to wait to find some from a t-top car.
Old Dec 16, 2008 | 05:06 PM
Stephen's Avatar
Car: 87 GTA
Lon
I just heard back from the guy I sold my visors to.....
He swapped them COMPLETELY, not just the flat parts.
His words exactly.....
"The mounts are exactly the same, just the size of the visors themselves are different. The t-top ones are tiny and useless. "
Old Dec 16, 2008 | 11:32 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
He obviously doesn't know what he's talking about:
Old Dec 16, 2008 | 11:48 PM
Stephen's Avatar
Car: 87 GTA
And obviously, you don't comprehend.....While the DETAILS might be different, even in your pic, the feet look the SAME SIZE. Meaning...Unscrew one, screw in the new...DIRECT swap items.
Old Dec 17, 2008 | 12:57 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
What about C&C t-tops? I assume they use standard hardtop visors. Also, did the factory t-top cars get the clip things to hold the visors in place, or was that only verts?
Old Dec 17, 2008 | 11:13 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I pulled a set of t-top visors from the junkyard and put them in my hardtop and they are huge and cover the rear view mirror. There is a difference in the sive of the visor because I have pulled a couple sets from cars in the junk yard and the t-top ones are larger.
Old Dec 17, 2008 | 11:16 AM
Stephen's Avatar
Car: 87 GTA
See...That is backwards from both the pics above & my buddys car.....He put my hardtop ones in, because his were small. The pic above shows the t-top ones to be smaller too....
Old Dec 17, 2008 | 02:54 PM
keepitcheap's Avatar
Car: 89 RS
Engine: 2.8 "mighty-mite"
Hey Guys,
I just pulled the old visors out of my 89 rs and sewed new ones. It was really easy if you are handy at all. I replaced the old "cardboard" with a piece of a pizza box top, and made them the visors out of black marine grade vinyl I bought at Jo-Anns for a few bucks. They look much better than the original ones and as ever you can "keep it cheap".
Old Dec 18, 2008 | 09:33 AM
John in RI's Avatar
I can "bolt on" a V6 MAF to my 86 IROC too - but that don't mean it's right ! Different style visors will "bolt-in" - but that doesn't change the fact that the Visor itself as well as the visor mounts are not the same.
The wrong visor will "flip" down without any difference in operation - but as the pic clearly shows, the angle of the visor will be at the wrong angle compared tothe roof when mounted. You know that there are 2 styles of roof consoles right,....... the same thing applies here. The "form" of the roof is different and different accessories had to be engineered to account for that.
P.S. C&C cars used the regular hardtop visors as they were hardtops with the roof cut off,........ the T-Top visors mount with 3 screws just like the hardtop style,..... and the T-Top visors are "shorter" than hardtops visors. ( the dif in length can be seen in the pic above. )
1MeanZ
Dec 18, 2015 05:39 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
