How acurate are the stock gauges in a 88 IROC?
Old Dec 29, 2008 | 10:47 PM
1fastiroc-z's Avatar
Car: 1990 IROC-Z Camaro
Axle/Gears: 10 bolt
Like the title says how acurate are the stock gauges in a 88 IROC? I am going to put a new motor in my car in a few months and I was think about going with all new auto meter gauges. Will the stock gauges be acurate or do I need the auto meter gauges?
Old Dec 30, 2008 | 01:01 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: How acurate are the stock gauges in a 88 IROC?
there about as accurate as a drunk person shooting a pop can from 100 yards away.
Old Dec 30, 2008 | 01:30 AM
Axle/Gears: 10 bolt
LOL I didn't think they could be real accurate. I think I will go with auto meter gauges.
Old Dec 30, 2008 | 02:13 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
yeah hes right, i put an iroc cluster in my RS, even changed the sending unit for the temp gauge ( yes it was the right one lol) and after i hooked up a scantool it was still 30* off.....thats ridiculous
Old Dec 31, 2008 | 02:00 PM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
I have had tons of problems with my rpms, they read anywhere between 300 to 2500 to high. It's always close during idle, but it gets ridiculous during driving, normal (like 30%) acceleration reads 3000+ rpm on my tach, and under full acceleration it is reading close to 7000 rpm.
I'd go with after market.
By the way, what are you doing with that Iroc motor? Are you selling it?
Old Dec 31, 2008 | 02:46 PM
Axle/Gears: 10 bolt
I am going to go with auto meter gauges.
I am going to get a 408 SBC Dart block and heads built for it with a 200 or 250 shot of nitrous. I will probably keep the 355 and rebuild it for a back up motor I may sell it but probably not, it runs well for a 355 it has a real small cam in its just a little bigger than stock, it has Trick Flow heads (ported and polished) on it, Forged pistons, Accel lower intake, large runners, 58MM throttle body, stock plenum all has been ported and polished. the previous owner said it got 15-20 MPG with normal driving. He drove it 3-4 hours away from home and never had a problem. The car ran 11.62 with a 125 shot. I think would run around 11.00 with a mild TPiS cam, mini ram intake and 150 shot. If I decide to sell it I will let you know.
Old Jan 6, 2009 | 08:15 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
re-wire , 20 year wires to brand new gauges, is still 20 year old response.
Old Jan 7, 2009 | 11:17 AM
wulfgar the pen's Avatar
Car: 1988 sc camaro, 1986 IROC
Engine: 2.8 v6, 305 tpi (for now)
Transmission: automatic, auto( for now)
as with anything in these cars, 20 years of wear and tear will preoduce 20 year old results, i agree ^ re wire everything for best results
and if you ever sell the engine, i'm interested
Old Jan 16, 2009 | 12:05 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
Are they about the same as an '86 Trans Am? My guages read oddly a lot. My oil pressure gauge is always maxed... even when I was low on oil. My tac doesn't ever go over 3k (not that it can't, it just doesn't). Just curious.
Old May 25, 2013 | 07:06 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
I didn't wanna make a new thread. So I'm reviving this from the dead.
Are the only accurate gauges aftermarket?
Old May 25, 2013 | 08:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
This might be a dead thread, but...
I don't see what everyone has against the factory gauges. The factory gauges in my 87 were DEAD ON accurate once I got the needles set right. This includes the wiring.
The only 2 gauges I can possibly see having the most problems are the speedo (with VSS and not cable, obviously, which an 88 IROC has a cable) and the tach. Because the circuits include capacitors, which do go bad over time (ask anyone with a Sega Game Gear and they'll tell you how good some caps are... They tend to lose video and sound), they will either lose accuracy or stop working altogether. And this will happen with ANY gauge after time, so it doesn't matter if it's a factory gauge or a $300 Autometer tach.
Old May 27, 2013 | 05:56 PM
jaybdaboat's Avatar
Yeah I don't want to spend 150 on a used inaccurate dash
Old May 27, 2013 | 08:33 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Uh, yeah... If someone is charging you $150 for a USED cluster, walk away. Unless it's a digital Berlinetta set, a digital GTA set, or a used Cyberdyne/Nordskog or aftermarket, you're definitely getting hosed.
I think I paid $35 shipped for the one I bought from a 90.
Old May 28, 2013 | 05:19 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
My temp gauge has been on 180 since I owned the car.
Also, I find the needles to get stuck often. Like, they hang up until you hit a bump. I'm trying to find a way to keep the oe gauges, with a digital read out my temp. Need to dissect a summit digital gauge and find some plexi.
Old May 29, 2013 | 10:13 AM
jaybdaboat's Avatar
Then I get need to get off ebay!
Where should I look?
Old Jun 5, 2013 | 09:34 PM
jaybdaboat's Avatar
No one know?
Old Jun 12, 2013 | 09:21 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
as OEM they aren't accurate. that being said, they can be calibrated by any good gauge repair shop
Old Jun 14, 2013 | 08:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As accurate as you want them to be. The Tach is notorious for being unreliable, but that's due exclusively to one resistor on the circuit board that's known to be a piece of crap. If you replace that resistor with a potentiometer, you can dial that tach in to be absolutely dead-nuts accurate. I did it in my Corvette, and plenty of folks on here have done it to their thirdgen tachs.
The rest of the gauges are all pretty good, but aside from the speedo, the rest should be able to be trimmed with modified resistances just like the tach.
Old Jun 23, 2013 | 10:46 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
did you look in the for sale section of this forum?or www.craigslist.com ?
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Derick15
Sep 17, 2016 05:28 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 11, 2015 03:17 PM
