window switch brackets
Old Jan 6, 2009 | 08:51 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Im putting a 4th gen center console in and i have done a search and i like the way everyone is putting them in the ashtray so you can close the hatch and it is very stealth looking now my question is what material are you making the bracket out of it, like what type of plastic because i was thinking about using plexy glass(spelling?) and after cutting it out just painting it black or i have an old 93-97 console and cutting it up and making it out of the material that it is made out of. but if anyone has a better idea im all for it thanks in advance
Daniel
Old Jan 6, 2009 | 08:57 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Re: window switch brackets
I think I would try to make it out of ABS plastic. Try googling "ABS Plastic Sheets."
Old Jan 6, 2009 | 09:43 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Plexi would work, so would any other plastic. I used a scrap piece of 16 ga. sheet metal that I had laying around. But, I do sheet metal work for a living, so that's the main material that I use for most of my mods.
Old Jan 7, 2009 | 01:41 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I agree with dust3r, I just went to ebay and typed abs plastic sheet and I used that for the window switches plate and the nitrous switches plate aswell...
Old Jan 7, 2009 | 10:24 PM
Dans87GTA's Avatar
thanks i will look into that and get it done, i was thinking about using metal but i think i will use abs plastic.
Daniel
Old Jan 8, 2009 | 01:09 AM
HCR13's Avatar
Car: 1987 Trans Am
plastic is MUCH easier to cut and fabricate with, specially on the interior...
Old Jan 8, 2009 | 05:15 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
i love the way the 4th gen counsel looks. if i had an extra hundred bucks layin around id buy one off ebay to put in my 88.
Old Jan 8, 2009 | 07:29 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
True...however plastic is also not as strong. I made my first one out of ABS and it worked well for awhile. But it started to flex, and eventually cracked on me.
A nice comprimise between strength and ease of "work-ability" is alum. Thats what I made my current one out of.
Because Im a pic *****....
Old plate vs. drawing.
Layout after the rough cut.
Plate vs. drawing.
Textured overlay. MUCH nicer than paint for a piece like this in my opinion.
Switches and light mounted.
con't...
Old Jan 8, 2009 | 07:30 AM
Car: 86 Trans AM
Backside.
Installed.
The aluminum mounts via two long self drilling phillips head screws right down into the console plastic, and I painted them black for looks. It feels much more solid than the last one.
J.
P.S...we can only put 5 remotely hosted pictures into a reply now???
Old Jan 8, 2009 | 07:31 PM
Dans87GTA's Avatar
All I have to say is thank you that was just what i was looking for, im going to tkae that idea and run with it now just for one more question do you have the dimesion of bracket thanks again im going to start working on it soon.
Daniel
Old Jan 8, 2009 | 07:42 PM
Car: 86 Trans AM
Well...I have the CAD file SOMEWHERE... I think its at work on my work machine. If it is...Ill send it to ya tomorrow. Shoot me a PM with your email address. What I can do is send it to you ready to print, and when you print it, it'll be 1:1. I can also give you dimensions...but its almost easier to just cut it out and trace it to your material.
Ill get something to you though.
J.
1992 Trans Am
May 10, 2023 07:19 PM
Genopsyde
Nov 11, 2015 10:46 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
