Could be a stupid question but where is the hatch gear
Old Jan 10, 2009 | 04:53 PM
deoverton's Avatar
Car: 1992 Camaro RS
I have the normal symptoms of you hit the hatch button and the the motor just runs continuous without the hatch moving and you have to unhook the battery to make it stop working. I have read a few post on here about fixing it but it never really said where it was at. Today I took the center peice of the interior plastic off and I didn't see it around. Am I missing something or what? Does anyone have the hatch gear for dummies guide on this with a picture cause I am lost. I just unhooked the wire that goes to the motor so I could at least use the key to open it and just raise and close it manually.
Old Jan 11, 2009 | 08:33 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Could be a stupid question but where is the hatch gear
It's inside the clear plastic housing, on the hatch motor assembly. The motor turns a worm gear, which turns the big plastic gear, which raises/lowers the latch. It's pretty easy to rebuild, you can get the needed parts from:
www.topdownsolutions.com
Cleotiz
Jan 6, 2018 08:56 PM
madsv1000
Aug 20, 2015 06:45 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
