Gauges
Old Jan 29, 2009 | 05:43 PM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
Gauges
Been searching through the boards looking at all the kinds of gauges there are. Seen a million different guys with autometer gauges, plenty with the Auto Zone addon gauges tucked onto the dash somewhere (like my oil pressure gauge lol), and then there's the guys still rockin the stock gauges.
Well, what I'm wondering is, are there any aftermarket vendors that sell the stock gauges, but with accurate readings and a pretty cool new look? While searching the boards I came across a guy's gauge layout that looks exactly like what I'm looking for, but I would like to get custom faces added in with a Trans Am logo of some sort. I love the stock gauges and I would like to have everything I need right in front of me without having to replace them with completly different aftermarket gauges like Autometer, the cheap addons, or having 2-3 gauges built into the pillar left of the dash.
Here's the pic of what I was reffering to...
https://www.thirdgen.org/forums/atta...s-dscn0273.jpg
Thanks in advance, and please, feel free to post any aftermarket gauge set up you've got going. I'd love to see your setup.
Old Jan 29, 2009 | 05:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Gauges
There's nothing available that'll directly replace a stock gauge.
Your picture looks like stock gauges with metal trim put around them.
Old Jan 29, 2009 | 05:54 PM
Car: '86 Trans Am
Engine: 305 H.O.
Re: Gauges
If that's the case, then is there anything that can be done with the stock gauges that will get them all reading accurately? I was interested in swapping all of mine out for something newer and better, but I don't want to go with anything that would change the appearance too much. I like the stock gauges, but they don't display anything accurately other than voltage and fuel, imo.
My speedometer doesn't work at all at the moment (haven't diagnosed that problem yet), the tach seems pretty accurate, fuel and voltage are great, oil pressure just maxes out as soon as I start and stays there... never changes, and I kinda broke my temp gauge... broke the sensor off while changing the spark plugs...
That pic I posted have different gauges than mine. Probably just a different year though, haven't been around too many differeny third gen birds. Mine is an '86.
Anyways, yeah, is there anything to do with them to keep the stock apperance, but get a better use out of them?
Old Jan 29, 2009 | 05:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Gauges
You can narrow down the problem to either the sender or the gauge itself, and replace whichever you need to.
Old Jan 29, 2009 | 06:23 PM
Car: '86 Trans Am
Engine: 305 H.O.
Re: Gauges
Would you happen to know why my Speedometer doesn't work? It has never even budged while I've owned the car. I've taken the gauge cluster out and cleaned everything I can clean, but I'm not sure what the problem is. It's an '86, so would that make it mechanical or electirc? I'm thinking it's electric because of the way the cluster "plugs" into the dash... but I could be wrong.
Old Jan 29, 2009 | 06:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Gauges
An 86 Firebird should have an electric speedo. If your check engine light isn't on, I'd suspect a problem with the speedo head rather than the sensor.
Old Jan 29, 2009 | 06:33 PM
Car: '86 Trans Am
Engine: 305 H.O.
Re: Gauges
That light has been on since I bought the car as well. That as wwell as the Brake light for some reason. Brakes are fine though... even replaced the master cylinder a week after I bought the car.
So that means the tranny has a VSS, right? What do I check to diagnose a problem?
Old Jan 29, 2009 | 06:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Gauges
Try pulling the codes first to see if the computer is complaining about the VSS.
Old Jan 29, 2009 | 06:46 PM
Car: '86 Trans Am
Engine: 305 H.O.
Re: Gauges
I honestly have no idea how to even go about doing that.
Old Jan 29, 2009 | 07:35 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Gauges
Flow Chevrolet says in their catalog that they "Exchange Thru AC Delco Repair Centers. Call for Price" http://www.gmpartsdirect.com/
Old Feb 17, 2009 | 11:42 PM
Car: '86 Trans Am
Engine: 305 H.O.
Re: Gauges
What are you trying to show me on that site exactly?
Also, what years of Firebirds/Trans Am can I replace my stock gauge cluster with? For instance, could I snag a cluster from a 92 and pop it into mine and it work fine or no?
Old Feb 20, 2009 | 11:17 PM
Kevin84Z28's Avatar
Re: Gauges
The cataloge says that you may be able to send your gauges in for repair to AC/DELCO. It says to call for pricing info. The web site is presented by Flow Chevrolet.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
