3rd Gen Firebird console repair
Old Feb 12, 2009 | 07:30 AM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
General question for everyone. I notice on the firebird consoles the sides have a tendency to seperate or pull away near or along where the hand brake is. I don't know if it is a adhesive that fails or just a poor design that over time causes the plastic to deform.
Has anyone here done a repair and how difficult is it to do?
Old Feb 12, 2009 | 08:32 AM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
Re: 3rd Gen Firebird console repair
My Firebird had done this. I took out the center console although I don't think that was really necessary. You should at least remove the center plastic in the console though. Then I roughed up the plastic with sandpaper where the foam had pulled away and put some Gorilla Glue down in there and clamped it together. Nothing was hard but it does take most of the day for the Gorilla glue to set up where it can't pull back apart.
Old Mar 4, 2009 | 02:12 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Amen to the Gorilla Glue. My son's 87 console had separated badly. A little Gorilla Glue and clamps, and it's looking good! I'll be posting pix in our thread.
Old Mar 4, 2009 | 03:44 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
just remember gorilla glue expands so don't over do it
Old Mar 4, 2009 | 06:41 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
what about contact cement?
Old Mar 5, 2009 | 06:04 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Yes, you do have to watch the Gorilla glue. One of the reasons for clamping is to contain that expansion... and watch your amounts.
Contact cement is what originally separated... and it tends to not work well on old foam, which gets crumbly. Gorilla Glue seems to work better.
Old Mar 5, 2009 | 01:08 PM
racerx520's Avatar
yeah i did this to mine when i did the interior of my car...i thought i was being smart and the only one who ever did this lol (the original owner just put screws through it and held it together that way) but unfortunately i forgot to sand it lightly and it all came undone again lol...go figure. i'll make a project of it again soon
Old Mar 5, 2009 | 07:17 PM
87v6Bird's Avatar
Engine: 406, LB9
I believe what helps the Gorilla Glue hold better is that it actually can expand into the old deteriorated foam and get a better hold.
Old Mar 9, 2009 | 05:29 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
OK, it took me a while, but here are the before and after pix of the console repair...
The vinyl had separated badly, and there was tons of old silicone or something like it in between the vinyl and the console shell. I cleaned it out, Gorilla Glued it, clamped, and then gave it a couple of coats of spray on truck bed liner (Dupli-Color) and then finished it with vinyl color spray. I suggest that you use the matte finish -- I used gloss, without realizing that there were different ones available. The gloss is a bit too shiny.
Attached Thumbnails 3rd Gen Firebird console repair-imgp0596.jpg   3rd Gen Firebird console repair-imgp0597.jpg   3rd Gen Firebird console repair-imgp0609.jpg
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Casey Meyers
Mar 2, 2016 10:46 AM
reiderz iroc
Aug 13, 2015 04:57 PM
