fixing my 91 tach
Old Feb 12, 2009 | 07:43 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
fixing my 91 tach
anyone know who can or what needs to be done to fix the tach in my 91Z? i thought i seen someone on here that can fix them. it works...just not even close to being accurate.
Old Feb 12, 2009 | 10:10 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: fixing my 91 tach
There is a faulty resistor bank on the circuit board of the tach. You need to establish which pathway of the board is faulty and bypass it by soldering a resister in place. I used a variable resistor so I can actually calibrate my tach with a computer readout.
Search and you will find detailed instructions. There is a long thread floating around somewhere about fixing the 91-92 tachs. It's really not as bad as it sounds, I did mine in an hour to two, including taking the gauge cluster out.
Old Feb 14, 2009 | 06:55 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
found the link....thanks!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
86maro_252
Oct 10, 2015 06:52 PM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
