Do most 3rd gens sound like junk inside!
Old Feb 24, 2009 | 02:06 AM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
I recently started driving the ROC to work and without my radio working i can hear every sound my car makes. I keep hearing a loud "clunking" sound like if its coming from the back hatch when i drive on bumpy roads. It also sounds like the passenger door glass is rattling and/or my door is not shut right,, which it is!
I know my suspension is stiff but its annoying the hell out of me!!! anyone else have a similiar problem?? is there a way to fix it?
Old Feb 24, 2009 | 04:47 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: Do most 3rd gens sound like junk inside!
It's not impossible, but very hard to make a thirdgen quiet. Cheap construction, combined with years of use and wear, can do that to a car. Someone on here made a nice write-up and I think it's a sticky now on how to fix some annoying door rattles. For the noise in the hatch area, check to make sure the spare tire and jack are secure. You may also have to adjust the rear hatch latch and the little plastic bumpers for it to make it stop.
Old Feb 24, 2009 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Someone, humm. Sticky in the Body forum.
JamesC
Old Feb 24, 2009 | 07:10 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Mines fairly loud. Lowering springs, poly bushings, lowpro tires all contribute to a rough ride.
Im putting Dynamat under my carpet this year to try to quiet it down
Old Feb 24, 2009 | 07:12 AM
carzwitballz's Avatar
Car: 91 Camaro RS/2005 Dodge 1500 4X4
Engine: 305/ 5.7 HEMI
My own experience. the jack and spare in the rear hatch tend to be loose.. The doors are heavy and tend to sag a little bit. You may try to put new pins and bushings. Like IrocZ said though...check the sticky
Old Feb 24, 2009 | 11:24 AM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
Haha, mine does. Everytime I drive on a road with sand or rocks all I can hear is all that crap slapping against my wheel wells. And I need weather stripping badly lol.
Old Feb 24, 2009 | 11:47 AM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Its the nature of the beast. My last IROC (1989) rattled and squeeked to high heaven--anytime I went over rough pavement I thought the thing was going to fall apart.
My current IROC (1988) doesnt seem to have that same problem--its alot more sound (not sure why). Ive heard subframe connectors will help, dynamat will help and going thru your car and tightening up every nut and screw can help too...Of course getting a radio back in the car may be the cheapest and easiest "fix"!! LOL!!
Old Feb 24, 2009 | 12:05 PM
Firebat's Avatar
On my 92, One side of my rear hatch bracket is busted, needs to be welded back down and it causes rattle. I was always going to stick foam inbetween any parts in the interior to make the dash rattle go away but haven't got to it yet.
Old Feb 24, 2009 | 04:07 PM
87_Injected's Avatar
Car: 2010 2LT RS
My 89 IROC used to rattle like crazy. It was a vert too which I'm sure didn't help. My 92 RS was good. Now my 87 IROC is good as well since the previous owner restored her well. No rattles here.
Old Feb 24, 2009 | 04:25 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
mine dont rattle that much but the hatch squeaks alot
Old Feb 24, 2009 | 07:54 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
That is a really loaded question. There is no easy answer, but everyone is right so far. New pins and bushings in your passenger door will probably help the most, but new weatherstripping will go a long way also.
Old Feb 25, 2009 | 11:28 AM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
The only real rattling I get is when I have my subs pounding thats cause the rear headliner plastic is broken.
Old Feb 25, 2009 | 01:39 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Other than the god awful sound my throw out bearing makes my car is quiet. Though if I am going over speed bumps or backing out of a uneven drive way my car makes horrible squeaking and borderline metal twisting sounds right at the driverside LCA.
Old Feb 25, 2009 | 03:25 PM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Do you have T-Tops? From what Ive heard subframe connectors can make a huge difference in stiffening up the body and reducing the amount of body flexing (and squeeking) you are hearing.
Old Feb 25, 2009 | 04:30 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Sub Frame conectors! Afterwards nut and bolt the car front to rear ( Tighten everything) It'll help immensely....
Old Feb 26, 2009 | 11:13 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Honestly, neither of my 3rdGens has been a rattle-trap. I get a little suspension noise in my current Formula, but that's because my struts are toast. I had an annoying "clink" sound that turned out to be the spare-tire/retainer. It's no Buick, but I have no serious complaints all things considered...
Old Mar 2, 2009 | 02:05 PM
99b4c's Avatar
Car: 99 B4C, 89 RS
Engine: LS1, 2.8
Transmission: 4L60E, T5
Axle/Gears: 3.23, 3.42
I'm going to have the RS interior floor LineXed (bedliner) after the subframe connectors are installed. My old 89 iroc l98 used to rattle and squeek from everywhere, whole interior was loose,dash,rear panels, door glass and hinges.
Old Mar 2, 2009 | 02:13 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
My LT supposed to be quiet but I still get some windnoise and other sounds. I agree with the other posts where the jack can sometimes get loose. I am too going to throw in some Dynamat when I get some more money.
Old Mar 2, 2009 | 03:15 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
My 88 GTA is actually pretty quiet. The only places I get a little rattle from now are the doors, and the seats used to squeak before I greased them up.
Old Mar 2, 2009 | 05:23 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Axle/Gears: 2.77
Thanx for all the replys. I thought it was just my car! Now i know its a common thing. Yeah cant wait for my radio,, it helps alot when i pump the volume up. Im going to go thru the whole interior and check for loose bolts..parts..etc. And for those who asked my car is a hard top.
Old Mar 3, 2009 | 07:56 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i removed my spare tire and jack.
my conclusion was that the tire was 20 years old, and the air tank to fill the tire was just as old and not likely to be any good anyway.
a lot of noise went away.
my hatch makes a lot of noise and it sounds like i have a toolbox in my trunk rattling around, but other than that, if the road is smooth, its a great car.
Old Mar 3, 2009 | 08:48 PM
johnnymotz27's Avatar
Car: '89 L98 G92 Iroc /'11 GS Vett
Engine: L98/LS3
Transmission: 700R4/M6
Axle/Gears: 3.27 B.W./3.42
I was totally surprised when i picked up my 88 IROC last week that the cars interior was very quiet not rattles or squeeks at all and it has T-Tops. It is most likely due to it only having 76K and as my 3rd car i cant see it racking up too many miles soon! By the way i just signed up today hello all!
Old Mar 4, 2009 | 08:09 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Welcome to TGO Johnny, Start a thread lets see some pics of your ride
Old Mar 6, 2009 | 04:28 AM
Louis_84's Avatar
Car: 1984 Camaro SC
Engine: 305 V8, LG4. For now...
Transmission: 700R4, for now...
Axle/Gears: ???
u no i dont think that mine makes a lot of noise...but i havent listened for them either. And i dont have a radio in my Camaro, so i have to listen to my car, or talk to a friend.
I wish i could go for a ride in her, and tell u what i hear but shes hibernating for the winter lol
Frozer!!!
Jan 19, 2024 04:55 PM
neekolzun
Aug 24, 2015 04:59 PM
reiderz iroc
Aug 13, 2015 04:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
