What are these dials next to the dome light?
Car: 87 GTA
Re: What are these dials next to the dome light?
You mean....The multiple dials forward of the dome light?
Those are just for time reminders/notes.....Mileage trackers, etc. They don't actually DO anything, but manually turn.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
thank god someone asked this question... been looking and looking for someone to post this so i could figure out if this was electric or manual! now i just need to tear it apart so i can get the freekin map light out of the top....
Car: 1987 + 1988 Trans Am GTA
Engine: 5.7 TPI L98 & 5.0 TPI LB9
Transmission: auto / standard
Axle/Gears: 9bolt BW, 3.27 PBR & 3.45
You actually don't have to tear the console apart, the map light comes out by simply twisting the black plastic ring counter clockwise. If you need to take the console off for any reason, just take the dome light cover off, you'll see two screws that hold the console up to the headliner, unscrew them and push the console towards the windshield, it will come off easily.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
From what i can find out that overhead console 1st
came out in the'84 berlinetta,came with a flashlight
-the flashlights are probably all missplaced by now...
Car: 1985 IROC Z28
Car: 1985 IROC Z28
NO FREAKIN WAY MAN.... STILL GOT MINE!!! WORKS LIKE A CHARM WHEN YOU PUT BATTERY IN.... DON'T LIKE TO THOUGH CAUSE IT STILL GETS COLD HERE AND JUST RUNS THEM DEAD WHEN YOU NEED THEM..... LOL THAT LIGHT IS FREAKIN COOL THOUGH
You can find the flashlights on ebay once in a while, but they go for at least $50. There's two different ones, one says "CAMARO" and one says "FIREBIRD". Many GTAs and Trans Ams had this option, actually almost every GTA I've ever driven had a console. Also there's consoles for TTop cars and consoles for hardtops, they're shaped a little different.
https://www.thirdgen.org/forums/faq-...oth-types.html
BTW, the dome light area in these is very fragile. If the bulb is left on too long, the plastic around bulb holder will melt. Some members remove the bulb, some replace with LED's. I like 84 1LE's idea in the following link:
https://www.thirdgen.org/forums/inte...ulb-sizes.html
The flashlights are engineering failures, IMO. At any rate, if you take them apart, clean the contacts thoroughly and apply some dielectric compound to them, they'll work a good long time.
RPO DK6 was produced from 84-87.
JamesC
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I used to set dates on those spoold all the time, but would always forget about them.You need a reminder to tell you to check the reminder spools!
Car: 87 GTA
