Overhead Console Bulb Sizes
Old Dec 27, 2008 | 09:01 PM
milleym's Avatar
Car: 1986 Firebird S/E
Engine: 2.8L 173cid V6 MFI
Hello All -
I recently purchased an 86 Firebird S/E.
The overhead console included the flashlight, which was a pleasant surprise, but both the dome and map light bulbs are missing. I went to the local auto parts store and the bulb that the store sent me home with wouldn't fit.
Can some one tell me what the right sizes are?
Thanks in advance,
-Mark
Old Dec 29, 2008 | 10:57 AM
milleym's Avatar
Re: Overhead Console Bulb Sizes
Update:
It looks like the answer is 194 for the map light, and size 561 for the dome light.
However, I bought 561 last night and it doesn't fit. I'm wondering if there is a part I'm missing.
I must be an idiot, because I can't see how this bulb is supposed to fit into the dome light bulb connectors that I have on my overhead console. I'll take some pics and upload them when I get home tonight to show you all what I mean.
The connectors look like they are designed to hold a cylindrical shaped bulb (c clips that run horizontally) and the one that every site online is recommending is a cylinder that has two loops coming out of either end that looks like it was was designed to be held by straight clips running vertically.
Can anyone out there with an overhead console do me a huge favor and take a pic of their dome light with the bulb in and out so I can either see how the bulb is supposed to fit, or so that I could at least confirm that I have some aftermarket wiring?
Thanks in advance,
-Mark
Old Jan 3, 2009 | 12:58 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I believe the bulb in the dome is the same style as the one used in the luggage compartment.It should have a small metal wire/clip on each end.I think the bulb "clips to the tabs(from the outside) of the dome light.It does not wedge inbetween the dome lights metal tabs.Personally though, i would'nt use this or any bulb there.The heat will eventually distort the palstic where the tabs snap in & the tabs will break off.I stuck a 35 LED circuit board there.Bright as hell & no heat distortion.Also festoon(561 type) style LEDs are not bright enough!
Old Jan 3, 2009 | 06:38 PM
milleym's Avatar
Thanks for your reply. The bulb you're describing is what I have, but the holder doesn't look like it is for this size bulb.
I'm finally attaching some pics shed some light on this...
Sorry about the poor quality; these were taken with the camera on my cell phone.
Attached Thumbnails Overhead Console Bulb Sizes-12-30-08_2156.jpg   Overhead Console Bulb Sizes-12-30-08_2157.jpg
Old Jan 3, 2009 | 06:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
One of the tabs on the dome unit seems to be missing/broken.This may be why you are having a problem attaching that bulb.There is also another similar bulb that is tubular with metal caps on each end & the same metal clips as the one pictured, but it will do little for you if that one tab is indeed broken off.
Old Feb 16, 2009 | 06:32 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
The map light bulb number is 906. There is an L.E.D. version which I have yet to purchase but will.
Old Feb 20, 2009 | 10:54 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Are there any direct replacement LED bulbs? I want something brighter then what I have. I say direct replacement because I remember reading that some LED require extra resistors soldered into the wiring before the light is used.
Help appreciated,
Mike
Old Feb 21, 2009 | 07:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by 84 1LE
II stuck a 35 LED circuit board there.Bright as hell & no heat distortion.
Sounds interesting. More info?
JamesC
Old Feb 21, 2009 | 10:50 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Scroll down to the 36 LED unit, 1156 type,white or whatever color you like.You can also find these on ebay.
http://www.superbrightleds.com/cgi-b...?product=OTHER
http://www.superbrightleds.com/specs/pcblamp.htm
Old Feb 21, 2009 | 10:55 AM
JamesC's Avatar
Thanks. Wiring and attachment?
JamesC
Old Feb 21, 2009 | 11:01 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Simple: Pos & Neg.I just spliced the end of the leads & wrapped them around the two prongs on the OH's dome light.The CB fits snug between the two prongs.
Old Feb 21, 2009 | 11:03 AM
JamesC's Avatar
Cool. Many thanks.
JamesC
Old Mar 3, 2009 | 03:30 PM
MY87LT's Avatar
Car: 1987 Camaro LT
L.E.D. is the way to go. Hey, maybe these lights wont crack the overhead consoles.
Old Mar 3, 2009 | 04:00 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
LEDs produce next to zero heat.So there is no distortion of plastic from heat like bulbs do.Also the dome lense wont crack or turn yellow!
Fronzizzle
Feb 9, 2017 09:31 AM
Veaceonee
Sep 29, 2016 08:15 PM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jetmeck
Sep 4, 2015 12:29 AM
