Best Rr view mirror glue?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
My damn mirror bracket fell of after 20 some years.Ive seen those glues at the auto parts place, but is there something better out there.Ive heard those glues dont always work very well.Anyone with first hand experience?
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
Re: Best Rr view mirror glue?
Yes I have one advice. Do not glue the wrong side...
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Yeah, what LoopingZ said.
Seriously, get the glue that comes as a 2 part epoxy. One part usually comes in a little white plastic tube, and the other is a greenish-blue liquid in a glass vial with a felt pad on one end. That is the only stuff I have ever had any luck with. Using that stuff, I never had a mirror fall off a second time. I tried some cheap stuff at Walmart once, it came with 2 black plastic mirror mounts and was some kind of gel paste stuff. Dried to the consistency of hot glue and held about as well.
Found a link for the good stuff:
http://www.autozone.com/R,282069/sto...ductDetail.htm
to do the job right its all in the prep. Make sure everything is spotless and free from oil from your hands. Let the glue set up for an hour or so then rehang mirror and you wont have to mess with it ever again.
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
I tried the stuff from the auto parts twice and no luck, I even let it sit for a couple hours before hanging the mirror and it still didn't hold. So I said screw it and took it to an automotive glass shop, they charged $10. and guaranteed it to hold, problem solved. Later.
Car: 1990
Axle/Gears: stock
its not sexy or exotic but pepboys carries it all the time and its cheap. AND IT WORKS.
do the prep and make sure everything is clean.
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Car: 73 Camaro
Engine: 355
Transmission: TH350
Axle/Gears: 3.23 posi
Clear RTV Silicone works just as good. Just prep with isopropyl (mirror & glass) and stick it in place holding it up there with Duct tape till it cures.
Car: 1987 GTA
Transmission: 4L60e
I put on aftermarket mirror about a year and a half ago and the car's been inside a shop in Texas since then (gets lots of heat). I had success with one of the decent looking kits from the auto parts place. Your best advice has already been given: prep the surface well. No oil or residue. Also - follow the instructions on the glue. I let mine dry for 24 hours.
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
I have also used the Loctite product on about 6 windshields -- and no problems. Just follow the instructions to the letter!!!! It works.
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
There's a guy with a Z28 for sale on ebay right now. One of the things he mentions is that the prior owner attached the mirror by putting a screw thru the windshield! LOL! At least he doesnt have to worry about the glue not holding!!
But he will have a cracked windshield to worry about...
Car: 1988 IROC
Engine: 5.7 litre
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
