Does your dash shake bad when you go fast?
Old Mar 7, 2009 | 04:39 PM
91R5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
When I get moving on the hwy it seems like it really shakes my wife was trying to hold it in place to get it to stop. It doesnt seem like its really loose or anything. Is this a common problem with third gens? is there a way I could fix it?
Old Mar 7, 2009 | 04:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Does your dash shake bad when you go fast?
Not that I know of. Make sure all the screws are tight and in place.
JamesC
Old Mar 7, 2009 | 06:33 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
usually at high speeds it is due to a wheel imbalance or driveshaft imbalance.
Old Mar 9, 2009 | 10:51 PM
krazy a's Avatar
Car: skeetchers
my 85 had a fan that was out of balance and the dash shook really bad above 60-65, changed the fan and it smoothed out. not likely but anythings possible.
Old Mar 9, 2009 | 10:56 PM
Stephen's Avatar
Car: 87 GTA
Mine doesn't shake at all. NO screws holding it down AT ALL....up to 80mph (never gone any faster in my car).
Your problem is most likely caused by an inbalance somewhere, like the tires/fan/etc.
Old Mar 9, 2009 | 10:59 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Alignment?
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
hell mine shakes at idle. It's my cam tho!
Old Mar 9, 2009 | 11:03 PM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
I think mine does a little, better yet the vent stuff under the dash pad does i took it off and one sides missing a piece for the vent on the right side, and the middle piece seems loose.
Old Mar 9, 2009 | 11:23 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
A lil while after I bought the car it started doing it.After chasing balance alignment and all kinds of things I found out I neede ball joints.That fixed it.
Years later,Did it again it was an out of balance tire.
Just recently had a leak a plug wouldnt fix and used some of that green slim stuff.It fixed the tire but it settles and causes the tire to be unbalanced.I had to keep it that way for a few months cause I got laid off my job.Had no choice.Bought a new tire and had it rebalanced when I started working again,fixed again.
It could be anything that spins,rotates or has to do with your font end in my opinion.
Old Mar 9, 2009 | 11:32 PM
Car: 1992 RS 6spd
Old Mar 10, 2009 | 01:02 AM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Its definitely not normal. I can drive 100 mph+ and my car is solid--not one shake or rattle.
Are all of your screws in place for the dash and are they tight?
Old Mar 10, 2009 | 09:59 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
I drove them when they were new
The dashes shook
There is a wee little brace in the middle of the dash that is supposed to hold all that plastic still.
Hail GM engineers!!!!
If you have a T-top 3rd gen it will be worse, less structural integrity
When I installed my sub frame connectors the dash shakes minimized and so did a bunch of squeaks and rattles
The dash pad screws work their way lose over time as well
Good luck!
Old Mar 10, 2009 | 10:05 PM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
The dashes shook
Good luck!
I drove them brand new as well and didnt have any issues with rattling.
My 1989 IROC I owned 10 years ago was a rattle trap and sounded like it was going to fall apart when you went over any kind of rough road. As I stated above my 1988 IROC is solid as a rock. Hard to say why there would be a variance from one car to another. I agree that T-Tops off less rigidity and convertibles are even worse.
redmaroz
Apr 25, 2017 07:14 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Fast355
Dec 2, 2016 06:33 PM
xxx3man`
Sep 23, 2015 10:37 PM
