Wiring Power Seats
Old Mar 7, 2009 | 10:54 PM
jerzies04's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Wiring Power Seats
Hi,
I'm trying to wire power from my fuse box to power power seat because my car does not have factory power seats and I'm trying to put in my new 4th gen seats. I know that I'm supposed to run the power wire from the fuse to the seat, but I can not seem to find the power cable to use. I know your supposed to use eaither an empty non-switched ignition port, or a switched ignition port it doesn't matter. Could anyone let me know which area this is exactly because I'v cut into like 6 wires and had to reattach them because I'v had no luck. If anyone could point me to this I would greatly appreciate it, all the wiring is set on there, and I already have an inline fuse I just need to know where to cut into.
Thanks,
Mike
Old Mar 9, 2009 | 05:25 PM
jerzies04's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Re: Wiring Power Seats
Hi,
Found out myself today, if you look in the way back there is a power wire going up towards the ignition. It is a red wire, there are a couple thin wires also, but you know its the power because its thick and red.
Old Mar 10, 2009 | 01:12 AM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I probably would have tapped into a wire for the power window--its close to the seat and wouldnt want to take a chance with my ignition wires.
Glad to hear you ran a fuse.
Post a pic of the new interior!
Old Mar 15, 2009 | 02:55 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you can tap it into the ACC fuse port, or you can just grab power from the power window wires. the ground will go from the seat to the seat stud, or just drill it into the chassis. looks like you are making it more complicated than it is.
Old Mar 15, 2009 | 05:28 PM
jerzies04's Avatar
Car: 1992 Firebird
Engine: 305 TBI
I got i done, everything works fine now. It wouldn't have been good to tap into power windows or acc because my drivers side window power is weak as it is without tapping more into it.
Old Mar 15, 2009 | 05:59 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
dont know why youd ever use the two continuously.
glad you got it working.
Old Mar 27, 2009 | 12:32 PM
89ls1rs's Avatar
the power is weak, or the window regulator is weak?
Old Apr 23, 2009 | 02:03 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I just picked up a set out of a 94Z for $75.....which wire is power under the driver seat? There's a black and an orange wire.......I'm guessing the orange?
Old Apr 23, 2009 | 05:06 PM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
the black wire is generally the ground wire...
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
