So my Camaro failed inspection.
Old Mar 11, 2009 | 03:59 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I failed because my steering wheel's diameter is to small and there was no horn, not because I didn't have a speedometer or seatbelt on passengers side. :O
So my question is, what is the diameter of a steering wheel with no airbag? Can I replace it with a certain aftermarket steering wheel?
I looked underneath the hood and could not find a horn. Maybe you can point me in the right direction? Worst comes to worst I have an air horn I could use.
Old Mar 11, 2009 | 04:13 PM
Stephen's Avatar
Car: 87 GTA
Re: So my Camaro failed inspection.
On your 89 or 91? For the 89, no air bag needed. For 91, an aftermarket, non-airbag steering wheel, will still fail regardless of size.
Old Mar 11, 2009 | 04:53 PM
JTNKTZ's Avatar
Engine: 355/350
1989.
Old Mar 11, 2009 | 04:55 PM
Stephen's Avatar
Car: 87 GTA
My stock 87 GTA steering wheel is 15", outside edge to outside edge. So maybe, 14", center to center?
Old Mar 11, 2009 | 05:04 PM
JTNKTZ's Avatar
Engine: 355/350
Alright, what kind of stuff do I need to know to buy the right steering wheel? Is there a certain bolt sequence of some sort? I have never put on a steering wheel or taken off so I have no idea what to look for.
Old Mar 11, 2009 | 05:06 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
iirc the horn is inside the drivers side fender. am i right?
Old Mar 11, 2009 | 05:07 PM
Stephen's Avatar
Car: 87 GTA
Got a pic of what you have now?
Chances are, you have an aftermarket wheel, that has that ring of like 10 little screws/bolts, on top of the steering wheel adapter, that is made to fit your stock steering shaft, then has the almost universal little pattern for almost all aftermarket steering wheels.
Old Mar 11, 2009 | 05:16 PM
Stephen's Avatar
Car: 87 GTA
That's where my 87 is.
Chances are, after you pull the horn button out of the center of the steering wheel, you'll find a single wire coming up the center, that attaches to the horn button. I'd say either it isn't attached at the steering wheel or horn or the horn is missing
Old Mar 11, 2009 | 05:38 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
why would you fail for no airbag, in tx you can't fail a car for no airbag. that shouldnt be why he failed.
Old Mar 11, 2009 | 05:41 PM
Stephen's Avatar
Car: 87 GTA
Um.....Yes you can in Texas. Airbags are a FEDERAL safety requirement & if you pass without one, in a car that originally had one, you SHOULD fail..... No way around that.
Old Mar 11, 2009 | 06:11 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
no it won't trust me (state inspector) and while it may fail a federal inspection, the STATE inspection is just that a STATE inspection, which means that if txdot doesnt say the car needs it to pass an inspection then it won't fail. Hell it doesn't even give you an option to fail a car for an airbag on the computer. However different state laws are different so, up north you may fail without them, but not here.
Old Mar 11, 2009 | 08:27 PM
JTNKTZ's Avatar
Engine: 355/350
It's an 89 guys air bags started coming in 90s for these vehicles with the new dash.
Old Mar 11, 2009 | 08:31 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Is your 89's steering wheel stock? or did it get replaced by a previous owner possibly?
If its stock I don't know why they would fail you, just saying..
But yeah, your horn is going to be inside your drivers side fender all the way to the front basically.
Old Mar 11, 2009 | 11:18 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
did u check the horn fuse? should be a relay somewhere too. just sayin...
Old Mar 12, 2009 | 12:50 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If all else fails move to Washington state. No inspection necessary.
And a junk yard will have a steering wheel/horn button to fit even if you take it back off after inspection. Just get one from a gm car about the same year.
Old Mar 13, 2009 | 01:56 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
But if the fuse is out, then other things won't work like the power locks, remote hatch release (if equipped), dome light, cigarette lighter.
The relay is up under the dash in the inconvenient "convenience" center.
Old Mar 13, 2009 | 11:21 AM
JTNKTZ's Avatar
Engine: 355/350
I do not know if there is a horn. There is none on my aftermarket steering wheel. Sorry I should have elaborated on it a little more.
I updated the OP with a picture of the steering wheel.
Old Mar 13, 2009 | 12:43 PM
Chevy8588's Avatar
ok i can see the picture now, try this look into the center of your wheel there. there should be a little hole, stick a exposed wire into it and then ground the wire to the center nut on the column, hear your horn? if so then all you need it the wire retainer and a horn button.
Old Mar 14, 2009 | 06:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Just make a LOUD "honk" when the inspectors try's to check its function!
Old Mar 19, 2009 | 10:59 AM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
find a crooked inspector. when i lived in VA all my friends went to this guy and just paid him for the sticker. i however was too cheap for that and kept my car registered at my parents house in FL.
Old Mar 19, 2009 | 12:02 PM
85TAracer's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
In NY these cars are golden to "pass" with the right inspector. (I am an inspector so I "inspect" my own vehicles) after 1995 vehicles are plugged into the state computer via the OBDII connnector. Our law states that if a vehicle originally came equipped with certain specified parts.. ie an airbag, then it must be on the vehicle still. BUT most inspectors see an old camaro or firebird with another wheel on it and would usually have no idea if it was suppose to have an airbag or not.
I suggest to find a stock wheel and horn, fix the horn, get it inspected and then take it back off. I hate small wheels so I keep the stocker on there.. just my opinion.
89GTAOz
May 16, 2020 09:31 AM
BADNBLK
Nov 16, 2016 09:12 AM
Caspar
Jun 19, 2016 11:19 PM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
slade5612
Aug 11, 2015 07:19 PM
