Seatbelt rebuild kits?
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i know that there are kits to fix up the recievers, but are there kits that fix the retractors?
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Seatbelt rebuild kits?
The retractor fix involved installing a metal wire clip to stop the rewind spring from falling off. If it has already fallen off it can be rewound by spinning it and then pressing it back onto the retractor assembly.
I've got a box of the retractor clips. They come in sets of 10 or 12 cost a little over a $1 each. Only two are required be car. The fix was for ....'83-86 cars I believe. The retractor spring was just held on by friction on two little plastic pegs.
well its mostly for locking. the drivers side is temper-mental. and the passenger side doesn't really lock. both retract well, they just have trouble locking
yeah its tough finding them, especially black ones that work. i've found new ones from factory but they were neither black or cheap
i've seen them on ebay mostly. it usually comes with new buttons and new metal pieces that go in on the sides
Car: 89 Iroc Convertible
They are still available.I get mine from a GM dealer.Usually get about 10 sets of the pushbutton kits at a time.More that likely you will have to have it special ordered as I dont believe the GM dealers stock them
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tonys91rs
Oct 10, 2015 03:31 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
