SLOW Power Windows & Mirrors
Old May 17, 2009 | 01:52 PM
Surfer Matt's Avatar
Car: 2008 Ford F-450, 1985 Trans Am
Transmission: Automatic
Axle/Gears: Stock Posi
My windows and mirrors do move are sluggish to move. Since it is both windows and both mirrors I'm not sure if it's power supply, each individual motor, or something else completely.
Any suggestions?
Old May 17, 2009 | 02:32 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Re: SLOW Power Windows & Mirrors
well for one you might want to clean the trcks and regrease them that should help some.
Our window motors tend to be slow anyways when compared to a newer model vehical.
Old May 17, 2009 | 03:27 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Well, first of all, are you sure they're definitely running slow compared to other Camaros and Firebirds? The window motors are know for being slow even when new so they may be working fine. If so, they all run off the same wiring harness so there could be a problem there. If all four are running too slow it's unlikely that all four motors have problems so it would likely be in the harness somewhere.
Old May 17, 2009 | 06:00 PM
Since this is my second 1985 T/A, and I've owned 4 T/A's over 15 years, I can definately say, that they are moving MUCH slower than normal F-body windows are supposed to.
What's odd to me is that all 4 motor functions are so slow (the two windows and the two mirrors). Before I replace all the motors and open the doors for track greasing, I wanted to make sure there wasn't a more common solution.
Power was my first thought. Can I divide the harness or do I replace the entire wiring system?
Old May 17, 2009 | 07:05 PM
Former Sponsor
Car: Too many
The power windows, locks, and mirrors are on a separate interior harness. Actually, on an '85 the power mirror harness runs together with the window and lock harness but is actually a separate stand alone piece. On your car both harnesses plug into the distribution block behind the driver's side front kick panel so you may want to check there. Since the windows and mirrors are on separate harnesses on your car the problem would probably have to be at the distribution block or ahead of it.
Old May 18, 2009 | 08:14 AM
That is GREAT advice. Thanks for the pushing me in the right direction. I pulled open the kick plate access to find the the Distribution Block, looked weatherd and tired. It's likely this could be the root of the problem. Looking to pick up a replacement today. And if it isn't the source of the problem.... well it looked like it needed replacing anyway.
Great post! Thanks!
Old May 18, 2009 | 11:03 AM
1Aauto's Avatar
Former Sponsor
Another thing that slows down electric window motors too are old dried out door sweeps. You can buy a can of silicone spray at the parts store to spray the old rubber around the window. This is a temporary fix and over time all seals should be replaced if damaged.
White grease should be applied to the track from time to time as well. The less drag on that window motor the longer it will last.
Old May 24, 2009 | 08:18 AM
Ya know it's such a simple thing, and yet I have never done that, ever. Great idea, Thanks!!!
Old May 24, 2009 | 11:55 AM
Camaroz2892's Avatar
Car: 92 Camaro Z28
I feel like this thread would be the perfect place to also ask my question.
My driver side window literally takes about a minute or two to close. At first it moves really slow and closes/ opens only half way before stopping. Then i have to wait bout 30 seconds to a minute until i try again. When i try again it closes/ opens the rest of the way. On a bad day it may even take three attempts.
My passenger window, on the other hand, closes just fine. Nice and Quick and everything. Thanks for your help.
Old May 24, 2009 | 11:59 AM
Stephen's Avatar
Car: 87 GTA
I've seen a thread here on TGO about upgrading the wiring size & feeding the motors with more power, making them much faster.
I'm sure a good will turn it up.
Old May 25, 2009 | 09:09 AM
Former Sponsor
Car: Too many
Your problem sounds like you definitely need to replace your motor. We have them available on our website if you need one.
Old Jun 1, 2009 | 05:26 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I ask thee to invoke your search powers, because I couldn't find it !! Can you see if you can since you might know some of the keywords ?
Old Jun 1, 2009 | 05:42 PM
Stephen's Avatar
Car: 87 GTA
First search....
https://www.thirdgen.org/forums/sear...archid=1953825
Fifth result down.....
https://www.thirdgen.org/forums/body...ate-power.html
Bigger gauge wiring and/or a separate Relay can also help. If your old motors are just worn, not much is gonna help, sort of replacing them. Even then, brand new motors aren't exactly very fast.
Old Jun 2, 2009 | 10:54 AM
1Aauto's Avatar
Former Sponsor
You're welcome.Here's a link to our Window Motor Section if you end up needing one.
Old Jun 3, 2009 | 10:10 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
Just for added info, I replaced the circuit breaker in the fuse box today and my windows move noticeably faster and smoother. It was a $4 part.
Old Jun 4, 2009 | 09:25 AM
1Aauto's Avatar
Former Sponsor
Cool, you would be surprised on how much old seals will slow a motor down, and that's on any vehicle.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
