Locks not engaging
Old May 27, 2009 | 05:45 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Locks not engaging
I'm changing my interior from gray to black and while the panels are off I am addressing a few issues. This is an 87 with power everything.
Manually, my locks work perfectly but with I use the power buttons they do not engage. I don't know where to start because I can't get my head in the door so see everything.
Old May 27, 2009 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Locks not engaging
Common problem with our cars. Clean with WD-40 and relube with white grease. You might consider doing the window tracks as well. As long as you're in there, check the following link for some ideas:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old May 27, 2009 | 06:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Are they even making any noise like they are attempting to lock ?
Old May 27, 2009 | 06:43 PM
DJ Delsym's Avatar
Car: 86 Iroc
JamesC
I will try that, what gets cleaned and greased?
Yes, the actuators do function. It seems that they don't push the 90* rod its connected to up high enough...
Old May 27, 2009 | 06:50 PM
deadbird's Avatar
Engine: TPI 305/ v6
Since they are working then, the link James provided will probably get them back to working again.
I had the same issue with my 'bird on the passenger side. If you hammered on the button enough it would eventually lock or unlock.
Taken apart, cleaned all the old dirt and lube away from all the moving parts, used some Slip Plate to re'lube' (even though it's dry graphite) and never had an issue again.
Old May 27, 2009 | 07:13 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
[quote=DJ Delsym;4171507]I will try that, what gets cleaned and greased?
in a word everything gets cleaned . then lube all pivot points , rollers & tracks , be sure to remove rubber drain plugs in bottom of door for drainage . ( you may find strange items in bottom of door ) . when dry & lubed re-install plastic sheeting before door panels . don't worry about old sheeting , throw it away . get new stuff from LOWES , HOME DEPOT , etc. . apply oversize section with hot glue gun , trim off excess with sharp knife . you will be amazed at the improvement . good luck .
Old May 29, 2009 | 10:13 AM
1Aauto's Avatar
Former Sponsor
Also if it's not unlocking the passenger side door from the master switch,there might be a broken wire in the harness between the door and the body of the car on one of the sides.
Hope this helps.
Also it wouldn't hurt to pick up a test light if you don't have one to help chase down the problem area.
T
Old May 29, 2009 | 11:48 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Had similar trouble when installing a keyless entry on mine a year or so ago. Even after cleaning and relubing I wound up replacing the drivers side actuator. Still available from GM too.
Old May 29, 2009 | 01:00 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
I have the same problem. I have to push the button 3-5 times to move the actuator a little bit at a time. its old solenoid man. I recommend new solenoids off www.rockauto.com or even autozone. swap one out, if it works then bam., if it doesnt just return to autozone and say that yo mixed years up on your car and you dont need the part anymore, get a refund. the white grease is a great idea. im going to do that to my window tracks, and save myself a a headache with slow windows..
Old May 29, 2009 | 01:09 PM
JamesC's Avatar
Clean and relube. Chances are the locks are fine; they're simply having to work though 20+ years of gunk.
JamesC
Old Jun 1, 2009 | 09:32 AM
1Aauto's Avatar
Former Sponsor
We carry the actuators too if you end up needing them.
Camaro Door Lock Actuator
jrdturbo
Mar 31, 2016 02:58 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
sahlomonic
Sep 20, 2015 07:15 PM
