92 cluster in an 87
Old Jun 28, 2009 | 04:29 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
92 cluster in an 87
i want to put the 145mph speedo of of a 92 z28 in my 87 z28. what do i have to do.
Old Jun 28, 2009 | 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 92 cluster in an 87
The 92 won't fit the 87 without major modification to the dash. Furthermore, the 92 speedo is electric, the 87 cable driven. The swap can be done with some headaches, but it might be more worthwhile to simply swap in a cable-driven 145.
JamesC
Old Jun 28, 2009 | 09:44 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yes, that is not an easy swap. The easiest way to do it would be to change out the entire dash. Also, James C is right, you would have to convert your car from a mechanical speedo to an electronic one.
Old Jul 1, 2009 | 03:09 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i thought the dashes weere the same in all f bodies also mines shot and i like the 92 style so id definitly like to do it once i finish my motor swap
Old Jul 1, 2009 | 09:05 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Don't do it uness you want to have tons of electrical headaches and spend a lot of time doing the swap. Like Thirdgen Ranches Denny said...swap in a 145 designed for the car's correct year. That would take about an hour at most to do.
Old Jul 1, 2009 | 09:14 AM
Former Sponsor
Car: Too many
If you decide you want to put in a 90-92 dash we will have them available on our website by the end of the week.
Old Jul 3, 2009 | 02:08 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
so the dashes are different? i thought just the clusters were different
Old Jul 3, 2009 | 08:33 AM
Former Sponsor
Car: Too many
Yes, the entire dash is different.
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
