Headliner Fix
Old Jun 29, 2009 | 08:18 AM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
Headliner Fix
Headliner around the T-Tops is sagging it appears as if one of the previous owners stapled some of it back up. Ive heard of people using glue I dont know if staples is the best thing for the ceiling lol any ideas thoughts opinions?
Old Jun 29, 2009 | 11:43 AM
1Aauto's Avatar
Former Sponsor
Re: Headliner Fix
Welcome to the website. We offer a few options to repairing your sagging headliner. We sell the ABS back headliners that are already upholstered for you,basically take it out of the box and install it into your car.
I also have a scrape and recover kit for customers that want to save money and wish to reuse the original pressed board headliner backing.It includes new fabric to recover the old board. AutoZone,Pep Boys Etc. offer a headliner adhesive that you can purchase to properly install the new fabric.
If you have any questions I'd be glad to help, here's a link to the headliner section on our site.
Chevy Camaro Headliner
Old Jun 29, 2009 | 12:56 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Headliner Fix
Do you guys have the ready to install headliners with all the openings for interior lights? More notably those of us that have the roof console in our cars?
Old Jun 29, 2009 | 01:06 PM
1Aauto's Avatar
Former Sponsor
Re: Headliner Fix
We offer the ABS ready to install headliners for both the T-Top & hardtop thirdgens. The do come prepunched to allow for the sunvisor mounts and also the map light locations.
Camaro Hardtop Headliner
Camaro T-Top Headliner
Old Jul 8, 2009 | 02:51 PM
Re: Headliner Fix
will these camaro headliners work for my bird though?
and how do i know if my pressed board headliner needs to be replaced or just scraped?
is it bad if the previous owner stapled it or if i do that?
Old Jul 8, 2009 | 02:58 PM
1Aauto's Avatar
Former Sponsor
Re: Headliner Fix
Hi,
Yes the will they are the same part number.Here's a link to the Fire bird listings too.
Pontiac Firebird Headliner
Pontiac Firebird T-Top Headliner
Old Jul 8, 2009 | 03:04 PM
1Aauto's Avatar
Former Sponsor
Re: Headliner Fix
The kind of depends on if it's water damaged and the board's all falling apart,the cloth also deteriorates over time. If the board is good and you would like to reuse it,we sell material for it. Some guys like the ease of just pulling a new one from the box and just being able to toss it in there.
Pretty much.Push pins make less of a mess.
Old Jul 8, 2009 | 04:40 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Re: Headliner Fix
GM did not have much forethought when they put a pressed fiberboard for a headliner backer board on a t-top vehicle.
Unfortunately, the condensation from the inside of the t-tops coupled with the sun when the tops are off usually make the board brittle.
If you are lucky enough to get the headliner out in one piece, especially around the seat belts, you can stiffen up the board with some fiberglass resin and hardner.
I chose to purchase a ABS board. It came with holes for a regular dome light and visors. I had to put extra holes for the overhead console. I have been very happy with my choice. Remember to change the headliner material over the speaker covers to match the new headliner, whichever way you choose to go.
DO NOT USE STAPLES (cringe)
Old Jul 9, 2009 | 11:19 AM
Re: Headliner Fix
Actually I already used staples and it worked quiet well I used one of those big shiney staple guns
Old Jul 9, 2009 | 11:29 AM
1Aauto's Avatar
Former Sponsor
Re: Headliner Fix
This happenes in quite a few vehicles. The Mustangs do it too.
Old Mar 8, 2010 | 05:36 PM
corlando52's Avatar
Car: 1984 Firebird SE
Engine: 2.8 L
Transmission: Automatic
Re: Headliner Fix
I bought the T-top headliner, already covered, from Hawks. The ABS sags. Any suggestions on how to sure up the headliner? I'd hate to screw it into the metal, but I don't see another option. Someone suggested Velcro, but the glue melts when it gets hot and the headliner sags again.
Thanks!
Chris
Old Mar 9, 2010 | 07:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Headliner Fix
Use a better glue to attach the velcro to the headliner and to the roof. Two part epoxy will ensure that it stays there forever, but if you ever want to get the velcro back off in the future, you can try a less permanent type of glue, like Automotive Goop, or a high temp hot glue. You can also use the same technique to attach the factory clips to the abs headliner that help hold it up by the windshield.
You can also add an overhead console, which will do a great job of holding the headliner up.
Old Mar 9, 2010 | 08:26 AM
1Aauto's Avatar
Former Sponsor
Re: Headliner Fix
Yah know what I bet would work for you guys,go to the parts store and buy some 3M double face tape. They use this to hold ground effects on. It should work perfectly for what you're trying to do.
Tony
Old Mar 9, 2010 | 02:01 PM
Jim85IROC's Avatar
Re: Headliner Fix
Tony, I'm not sure how well the tape will stick to the adhesive side of the velcro though. At least with the glue/epoxy, it should stick. If not, I know it'll stick with the non-adhesive backed velcro.
Old Mar 9, 2010 | 02:17 PM
corlando52's Avatar
Engine: 2.8 L
Re: Headliner Fix
I've used Loctite Permanent Spray Adhesive on adhesive backed velcro when I was reupholstering my rear seats, and it holds remarkably well, even on fabric, and doesn't melt in the heat. I think I'll give that a try.
Thanks!
Chris
Old Mar 10, 2010 | 09:54 AM
1Aauto's Avatar
Former Sponsor
Re: Headliner Fix
Not sure I understand.I was suggesting using that instead of the velcro for the middle part.
Old Mar 10, 2010 | 02:41 PM
Jim85IROC's Avatar
Re: Headliner Fix
Oh. I thought you were suggesting that you attach it to the velcro to let the velcro stick.
I'm a big fan of the velcro route for the sake of removability... the key is getting the velcro to stick to the two parts.
Old Mar 16, 2010 | 01:38 AM
h_worker's Avatar
Re: Headliner Fix
hi, tony i own a 86 t top camaro ,how much to ship a t top replacement to sydney .australia.[down under]thanks rob
Veaceonee
Sep 29, 2016 08:15 PM
92firebirdguy
Sep 1, 2016 07:53 AM
PurelyPMD
May 5, 2016 04:57 PM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
