Steering Wobble. Where can I buy new bearings for upper column?
Old Jul 6, 2009 | 05:20 PM
AZ_James's Avatar
Guys,
I have a ton of wobble on my steering wheel. It appears to be only the steering shaft that is moving.
I tore it all apart yesterday down to the 4 tilt bolts. They were tight. My bearings were crap. I tried to make due and put all the little bearings back into the old worn out plastic holder but they started falling apart before I could get it back together. The bearing race refuses to stay on the lower portion of the housing where they meet the ball joint. There seems to be some space between that ball joint and the lower bearing when its all back together.
Is the ball joint designed to ride right up against that lower bearing? I know if I pull out on the steering wheel, everything seems to tighten up nicely but the locking plate is on correctly. So is there any way to get it tighter or should it be fine with a set of good bearings riding on the top and bottom?
Does anyone know where I can purchase new bearings. Aftermarket ones might be nice too if available since it seems the GM design doesnt hold up too well.
Please let me know if anyone knows where to get parts or if you have any ideas of other problems that could need fixing. I noticed a rebuilt upper column on ebay, maybe I can go that route, but would love to find the bearings by themselves since it will be much cheaper.
Thanks,
James
Sorry for the double post. If you have the power, please delete the other post. Thanks
Old Jul 6, 2009 | 09:41 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
Re: Steering Wobble. Where can I buy new bearings for upper column?
not sure were to get new bearings at you can usally get ones a new colom at the bone yard for cheap though if you cant find them
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
