Dash question, what is this light for?
Old Jul 29, 2009 | 02:48 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I got a 88 IROC L98, 700R4, and on the left side of the steering wheel I have the lights switch and the toggle switch for the fog lights. On the right side I have the cigg. lighter and a red indicator light.
Does anyone else have that same indicator light?
What is it an indicator for?
Is it factory? (I does NOT look like it was hacked in there, it looks very factory.
Did these cars ever come with a security system?
I have no idea what its for, I have never seen it go on, flash etc.
Ill snap a pic if needed.
Any help would be appreciated.
Old Jul 29, 2009 | 02:56 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: Dash question, what is this light for?
id like to see
Old Jul 29, 2009 | 05:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
All I've ever seen below the cig lighter is the rear window defrost switch - so I'm assuming it's a mod from a PO.
Old Jul 29, 2009 | 07:11 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I will use the banned word "rare" but if its what I think it is, it was actually a dealer installed option. I have seen it only a few other times, the RPO code was F#394 . Evidently it was some system called ID-KFA that was part of the throttle body system and was some sort of performance indicator. From what I remember, it came on when you hit "Full Engine Power" . I think it was a California thing because my friend had a "California IROC" in original condition that came with this option. .....
Old Jul 29, 2009 | 08:48 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Well my car did come from california, but its not a "California IROC"
The RPO code is listed as F394?
Old Jul 29, 2009 | 08:55 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Heres the pic.
Old Jul 29, 2009 | 08:57 PM
Chevy8588's Avatar
no window defrst correct? probably part of an old alarm system, I have seen them without rear defrost and just a regular block off plate there, best bet? pull off the cover (two screws) and see where the wire goes. no way it can be F394 because RPOs are 3 digits, also all F codes are suspension related
Old Jul 29, 2009 | 09:02 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
See thats the thing, it has had 2 previous owners, which I am in contact with. Other then the tires and a new rad, the car is the way it rolled off the floor. Im baffled on this one. Maybe ill pull the plate and see where they go.
Old Jul 29, 2009 | 09:10 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
someone installed an alarm somewhere along the line. My convertible had one in there too. To my knowledge there was no factory alarm to choose from now that isn't saying you couldn't get a dealer installed alarm but not positive what was there to be offered.
Old Jul 30, 2009 | 08:57 AM
Car: 1987 IROC Z
Doh... I forgot to mention that I mad that story up... pure
On the other hand, my old RS actually had a similar switch and I am pretty sure it was the rear defroster.
Old Jul 30, 2009 | 10:52 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Ok, I got it, your one for those guys who has no life but to search the forums and make up BS storys to boost your post count.
Old Jul 30, 2009 | 11:31 AM
Chevy8588's Avatar
ok lets not have something escalate here, though i will say that was pretty dumb goku, and a little demeaning to his intelligence >.> at least we pretty muchh know what it is, like i said, pull the panel and see where it goes, could have been an alarm light, coulda been a confirmation light for something like the cooling fan
Old Jul 30, 2009 | 11:35 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Wow goku that was pretty sad, but Do what chevy said and track that wire!
Old Jul 30, 2009 | 12:06 PM
mikeiaz's Avatar
that is an indicator/warnnng light for an old VIPER alarm system - seems like lots and lots of 3rd gens had this system installed when new
Old Jul 30, 2009 | 12:45 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Interesting. I have no remote that came with the car. Where were these alarm modules hidden, I would like to try and get it to work if it is infact an alarm system.
Old Jul 30, 2009 | 01:06 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
it an old alarm, u prob have it there since u have fog lights... mine is on the other side
Old Jul 30, 2009 | 01:27 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
if the alarm was still hooked up the light would go on and flicker when armed.
sort of a warning. some people just hooked up the light to make people think it has an alarm on it.
just noticed someone else said it. mine had a black widow arlarm and got that red light.
its aftermarket.
i took a few pics - light and the sticker.
it was probably the same product in the same box with a diffeent lable. viper here blackwidow there. probably had hundreds of names.
my wife decided it was making her battery go down so i had to have it taken off. lots of hanging wires. installed in march 1990 and took it out of her car within a year. my 91 - bought in april 90 had the same one for 6 5 years.
Attached Thumbnails Dash question, what is this light for?-snc00221.jpg   Dash question, what is this light for?-snc00217.jpg
Old Jul 30, 2009 | 05:58 PM
mikeiaz's Avatar
use the search function to find one of my posts/questions from 6/24/09 titled VIPER alarm problems - in the responses to that one there is a link to a website where you can download PDF installation guides for various alarm systems - if it was a VIPER alarm it is likely a model 300, the control modules were usually mounted under the console (loosen the shifter plate and look underneath) - there is a picture of the control module on my car in that post I referred to, and there probably would be a valet/bypass button or switch mounted under the dash on the driver side, maybe in the plastic hush panel cover above where your shins would be. If you have not already done so look underhood to see if you can spot an alarm siren - they usually had an approx 4" black megaphone style horn and are obvious to spot.
Old Jul 30, 2009 | 06:04 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
mine has an identical light in the center console and it belongs to my alpine alarm system. my control module was under the drivers side dash
Old Jul 31, 2009 | 06:09 PM
Car: 1987 IROC Z
Bah.... im one to admit when im wrong, im not usually the type to do that sort of thing. My apologies for the ill placed comments camaro1185. I'll refrain from this point forward.
Old Jul 31, 2009 | 06:16 PM
Car: 1987 IROC Z
If it is of an redeeming value, after seeing that picture, I would agree that it is an aftermarket alarm system. It might be wise to trace down this alarm and if you cant make use of it, remove it. I had an alarm/kill switch in my car for some time and it stopped working well so I disabled it (or so I thought) . I come out to start my car one day, and I can't get the ignition to kick over. It ended up that I needed to remove that system altogether because it was still connected to my ignition wire and somehow it was activated. But at the same rate.. these are thirdgens with 80's technology so "if aint broke then don't try to fix it" may be applicable here.
Old Jul 31, 2009 | 06:42 PM
Chevy8588's Avatar
agreed with the whole finding and removing deal, i used to work for a GM dealership and ive seen alarm modules go bad, they tend to cause no-start conditions as well as dying while driving, and i gotta say goku, ive been a long time lurker, short time poster, you are probably the first poster i have ever seen admit fault and not cause a HUGE case of BS. you have my respect man lol.
Old Aug 2, 2009 | 10:43 AM
Car: 1990
Axle/Gears: stock
a common trick was putting a fuse inside of the wiring bundle under the hood - where there are wire covers that can be split and hidden inside of them. very hard to trace them.
Old Aug 7, 2009 | 08:40 PM
mtflyboy's Avatar
Car: 1991 Z28
Hey i have that lil red light in my 91 z28 too! But there is no alarm system that i can find. especially no mini megaphone thing.
Old Aug 7, 2009 | 08:46 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
well i took the panel off to see where it was hooked up to and to my surprise, it looks like its a dummy light. mine wasnt connected to anything, in fact the wires werent even stripped.
Heres a pic.
Old Aug 7, 2009 | 09:08 PM
Chevy8588's Avatar
lol that is your run of the mill radio shack red LED that when powered, most likely flashes, probably put in as an attempt as a faux theft detterent system
Old Aug 9, 2009 | 01:15 PM
fubar_1179's Avatar
Car: 89 Camaro RS Coupe
Engine: 305 TBI
Axle/Gears: Stock I Guess
I have the same red light in the same place. I drive an 89 rs 305 TBI and i have no alarm system(just vats) and i have always wondered what it was for cause it has never came on. I guess i will pull it out to see if its hooked up to anything.
Old Aug 9, 2009 | 01:40 PM
mechanic1992's Avatar
Car: 1987 IROC-Z
I have two red indicator lights on my 87 IROC one below the cig lighter and one infront of my shifter, same thing?
Old Aug 9, 2009 | 01:53 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
its aftermarket.
That second picture has nothing to do with a alarm. Its for the VATS system.
Old Aug 9, 2009 | 02:03 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
What does it have to do with the VATS system? Care to enplane.
Old Aug 9, 2009 | 06:50 PM
Car: 1990
Axle/Gears: stock
well above the vats sticker which came with my 90 and 91 there is a sticker that says black widow. that was the aftermarket alarm system. not the part that said vats.
part of the discussion had to do with different types of alarms that used the same light and probably the same alarm with a different lable on the box.
VATS - Vehicle Anti Theft System - did not want anyone to get confused by the two signs.
Old Aug 9, 2009 | 09:46 PM
Krik's Avatar
Engine: 5.7 TPI
My old eyes totally missed the black widow sticker.
Thanks for catching that one for me Tony.
Old Aug 10, 2009 | 12:45 AM
Car: 1987 IROC-Z
ok, still, i have two of them in my 87 IROC. and i dont have that VATS sticker on mine. is it still the fake security system?
Old Aug 10, 2009 | 09:59 AM
Car: 1990
Axle/Gears: stock
if your talking little red lights that has nothing to do with vats - its just that the aftermarket installer put it by the factory vats sticker.
the red light has nothing to do with vats. completely separate.
and like i said the red lights were sold separately at some stores so you could just hook it up and it operated with a battery so you could switch it on and it would blink like you had an alarm and you would not have to tie into the actual electrical system.
as for 87 - dont really know when vats started. i had two new camaro's a 90 and 91 and both had vats from the factory, but the red lights were added later with the aftermarket alarm.
before that i had 5 other's bought new including a f/b and i dont think they had vats - actually im sure they didn't.
Old Aug 10, 2009 | 06:31 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have the same red indicator light in my 92 RS, and it has something to do with security. My light is under the headlight switch though.
Old Aug 10, 2009 | 06:47 PM
Twin_Turbo's Avatar
I had an identical annoying blinking led there:
Old Aug 10, 2009 | 06:48 PM
Twin_Turbo's Avatar
double post
Old Aug 10, 2009 | 06:55 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
ALARM LIGHT! Mine is located by the shifter and its a viper alarm. The actual unit was removed i bet.
Old Aug 10, 2009 | 07:10 PM
I just removed a little bull horn device on the drivers side. Nobody gives a hoot when they go off anyway. My little red light still stays on anyway. Just gonna leave it I guess.
Is this a part of a viper alarm? Dealer installed?
Old Aug 10, 2009 | 08:09 PM
AC's Avatar
AC
Car: Used to drive a camaro
Matt, that's just an indicator light for some aftermarket accessory or system someone installed. Could be a fan light, security system, etc. They're VERY common or atleast used to be common with different aftermarket systems. I personally would NOT want any 80's or even early 90's security system in my car. They're typically an ignition kill type of system. I've had 4 bad experiences with that type. 2 in my first Camaro and another 2 in different vehicles. They are sub-par IMO to systems of today.
Think of it this way. When you remove the pilot light you have a pilot hole to drill for the line-lock system switch
Old Aug 10, 2009 | 08:17 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
that looks like an old alarm light that told you if the system was armed or not my kitt had it as well but my old viper system worked amazingly
now if i can find some old viper alarm logo stickers that would be awesome
Old Aug 11, 2009 | 05:42 AM
  #42
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Ya i pulled the panel and its not hooked up to anything, so im thinking i dont have an alarm system. I also looked under the hood for a different "alarm horn" and looked under the shifter area for the alarm module and dont have either. I think it just a light that i can connect to whatever i want.
Old Aug 11, 2009 | 10:15 AM
  #43
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
. . . as for 87 - dont really know when vats started. i had two new camaro's a 90 and 91 and both had vats from the factory, but the red lights were added later with the aftermarket alarm.
VATS started in '89 on the Camaro. A year earlier on the Corvette. It's simply a resistor (one of a dozen or so different resistor values used) that's found in the key. If the ignition system senses a key with a resistor and of the correct resistor value, the car would be allowed to start. That's it. It had no alarm, no blinking light, and didn't need to be armed or disarmed. It was a totally passive system.
As mentioned by others, that light is totally aftermarket and you can do with it what you please.
Old Aug 12, 2009 | 12:16 AM
  #44
Car: 1987 IROC-Z
oh ok, thanks guys
Old Aug 12, 2009 | 08:20 PM
  #45
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Originally Posted by mechanic1992
oh ok, thanks guys
The camaro i just got from my dad has that light but its underneath the headlight switch
Old Aug 12, 2009 | 08:27 PM
  #46
That's where my little red light is also. It has something to do with the security system.
Old Aug 13, 2009 | 12:34 AM
  #47
Car: 1987 IROC-Z
Yeah, like i said ive got two one under the cig lighter and one on the shifter panel. i dont know why the second one is there really but oh well haha
Old Aug 13, 2009 | 05:35 PM
  #48
fubar_1179's Avatar
Engine: 305 TBI
Well i have one below the light switch on the left side of the steering wheel, And a whole under the Cigarette lighter where it looks like one used to be. The one under the light switch has one blue wire coming out of the light, didnt trace it yet. But it looks like the light was supposed to have 2 wires coming from it but one had pulled out prolly from the PO.
Old Aug 13, 2009 | 05:52 PM
  #49
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
well i must add i have a yellow lights that pops out ! located in the middle left on my dash on my 92 ! talk with the po no alarm and no hacked up fuse box and ideas ! ill snap a pic tomorrow fellas thanks !
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
