need help with a seat swap!
Old Aug 2, 2009 | 01:42 AM
j3rry92's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8L V-6
Axle/Gears: stock
I have a 1986 trans am with a flawless interior, but poor body, and a 1988 firebird with an excellent body and new paint, but could use some new seats. i am wanting to swap the seats out. my problem is that the transam has an electronic drivers seat while the firebirds is manually adjustable. i know the seats will fit and bolt right in but, is there a way to convert the firebird to make the electronic seat work? or do i just have to swap the seat tracks and stick to the manual way? help would be much appreciated.. thanks.
Old Aug 2, 2009 | 01:53 AM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Re: need help with a seat swap!
Take a look when you swap the seats. Most had the wires for them. I have seem people posting about the same thing in the past. You should have the wires for it but if not just take out of the donor car.
Old Aug 2, 2009 | 01:55 AM
j3rry92's Avatar
Engine: 2.8L V-6
Axle/Gears: stock
i dont believe the wires are there.. ive took the seats out previously. ill double check. but if i did take the wires out of the transam everything would match right up and work properly?
Old Aug 2, 2009 | 02:06 AM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
It should. Later.
Old Aug 2, 2009 | 04:13 AM
Twin_Turbo's Avatar
All you need is power and ground, so if anything you could wire it fused directly off the battery and a good ground. It's a no brainer.
Old Aug 2, 2009 | 08:27 AM
j3rry92's Avatar
Engine: 2.8L V-6
Axle/Gears: stock
alright thanks i thought it would work out like that. im probably going to get started on it later and give it a shot.
Old Aug 2, 2009 | 09:46 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
the wires are not there. its a common myth spread on all boards that its all the same wiring harness throughout all cars.
that wiring hairness you have with the electric seats is worth more than $100.00.
be very careful how you take it apart. there are two important wires. one will go to the body and should be the ground attached over by the shifter.
then there is a wire which is hot. look where that wire connects into the fuse box. my electric seats needed a 25 amp fuse and i got a new harness and spliced into that very fuse.
there there are wires that go over the hump and into the passenger seat. that seat has the air pumps for lumbar and side support. it should also have two vaccume tubes - so that the pump will work on the drivers seat. apparently gm decided tha the passenger seat needed the compressor and the hot lead needed the drivers seat.
and it is one harness that goes from the drivers seat to the passenger seat.
let me know if you have any more questions i have already made the swap.
Old Aug 2, 2009 | 10:00 AM
j3rry92's Avatar
Engine: 2.8L V-6
Axle/Gears: stock
alright thanks.. yeah that makes alot more sense i figured it consisted of more than what most people make it out to be. ive heard from a mechanic that it is a lot of work and most companies would charge a lot to convert it. thats why i figured it could be done on my own. thanks again. ill let you know if i have any questions about it.
Old Aug 2, 2009 | 03:26 PM
Twin_Turbo's Avatar
Maybe not for the seats but it is for AC and related items. Have a non AC 88 and the connectors for all the AC crap is there, clutch, hi lo pressure switch..blablabla... factory zip tied together and just left there.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
MORREALE5
Sep 13, 2015 09:16 PM
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
