Guage swap?
Old Aug 3, 2009 | 12:33 AM
Winidas's Avatar
Guage swap?
I have a 90 RS and I absolutely HATE the 90's style guages. I don't like the shapes of the guages or the color used in them. I used to the an 82 belinetta and I loved the gauge style of that dash. Basically what I would like to know is how hard it would be to swap to a pre-yellow style guage cluster or possibly a guage cluster using dakota digital guages. Any help would be very appreciated and thanks in advance.
Old Aug 3, 2009 | 07:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Guage swap?
Swapping to the earlier cluster (pre-90) would require major modification since the two clusters are shaped differently, though you could swap dashes. If Dakota makes a panel for your car, swapping it in would probably be much easier than the alternative.
JamesC
Old Aug 10, 2009 | 11:41 PM
mtflyboy's Avatar
Car: 1991 Z28
Re: Guage swap?
arent there some sweet glow guages and white ones out there so we dont have to have yellow?
Old Aug 11, 2009 | 12:41 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Guage swap?
I like the 90s gauges a lot better, but I hate the black with yellow on it. But I'm very happy with how mine look. In fact, teh dash and dashpad are about the only parts of my interior Im happy with at all lol.
They're a little harder to see around dusk than stock, but this video is about that time... and you can see em just fine.
http://s232.photobucket.com/albums/e...t=100_9387.flv
(The stock tach is disconnected just because it's so inaccurate, but I think I'm gonna put it back soon)
Old Aug 23, 2009 | 11:59 AM
mtflyboy's Avatar
Car: 1991 Z28
Re: Guage swap?
are those like billet ones?
Old Aug 23, 2009 | 09:50 PM
andrewmp6's Avatar
Re: Guage swap?
Dakota only makes them up to 89 your sol for a 90 unless you change the dash which is fun.
Old Aug 23, 2009 | 10:31 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Guage swap?
But you can have them made to order. Just send yours in and they retrofit their gauges into it.
Here's a shot of my 92 gauges, cost me about $900 at the time, now over $1000.
It's not a plug and play operation though. You need to find the input to the original gauges on the harness and tap into it, then route that to the Dakota Digital microprocessor.
Old Aug 24, 2009 | 01:30 AM
Winidas's Avatar
Re: Guage swap?
Those look amazingly better than the ones in there now. Does Dakota Digital provide an accurate wiring diagram depicting what wires I need to splice to the cpu?
Old Aug 24, 2009 | 02:40 PM
Al Hasse's Avatar
Re: Guage swap?
The instructions supplied by Dakota Digital are pretty generic. They at least tell you the color the wire "should" be for each make. You'd be better off opening an account with All Data, there you'll be able to find almost every wire and connector in the car for anything you want to do - www.alldata.com
Ghettobird52
Jul 5, 2024 11:18 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
