Which auto-down window switches ?
Old Aug 6, 2009 | 12:49 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Im doing a modification of the auto-down window switches and I am curious about which GM vehicles from 92 and up came with auto down switches. Its likely that they all use the same wiring setup (perhaps not some of the newer models) . The switches from the Saturn SC's work with little modification to wiring, what other auto-down switches exist ?
Old Aug 6, 2009 | 12:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Which auto-down window switches ?
4th gen cars with electric windows - my 1997 Z28 has 'em.
Old Aug 6, 2009 | 01:35 PM
87350IROC's Avatar
Car: 87' IROC
Why not buy a DEI 530T module and convert your stock switches into auto-down and auto-up. I have one. Its easy to wire up and works really well.
http://www.amazon.com/Window-Automat.../dp/B0009IP4SG
Old Aug 6, 2009 | 01:46 PM
Car: 1987 IROC Z
Does it have the auto-down feature on atleast one of the switches ? i am also looking for something that has individual switches rather than two of them combined.
Old Aug 6, 2009 | 09:31 PM
Car: 1992 RS
Engine: Carbed 350
On the 4th gen cars, there is a driver switch panel on the driver door with 2 switches, one for driver window, one for pass window. The driver window switch on the driver door does auto down, but the pass switch doesn't.
But, on the pass door, there is a switch for the pass window, and it does auto down.
So I guess you'd have to have a driver window switch from the driver door, and a pass window switch from the pass door (or else two of either).
Make sense? I think I even confused myself
Old Aug 6, 2009 | 09:33 PM
Car: 1992 RS
Engine: Carbed 350
Do you have to have a module for each window switch?
Old Aug 6, 2009 | 10:15 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
no one will work
Old Aug 6, 2009 | 10:51 PM
87350IROC's Avatar
Car: 87' IROC
One module works 2 windows.
Old Aug 8, 2009 | 07:20 PM
Car: 1987 IROC Z
Are the 4th gen switches seperate, meaning are they individual switches are are they mounted on the "same plate ? Any other GM vehicles that anyone owns that come with this ability ?
Old Aug 8, 2009 | 07:24 PM
87350IROC's Avatar
Car: 87' IROC
omni,
Can you explain a little further what you are trying to do? Do you want to replace the stock buttons? Do you want them to be seperate?
Old Aug 8, 2009 | 07:40 PM
Car: 1992 RS
Engine: Carbed 350
On the 4th gen driver door, the switches are sepeate on the same 'plate' - you could remove them from that plate and mount individually in their own seperate holes. On the 4th gen pass door, there is only the one switch, so yes it is seperate.
I like the idea of that module listed above, and at $54, you can't beat the price.
Old Aug 8, 2009 | 09:19 PM
yoshirocks702's Avatar
Car: 1984 Chevy Camaro Z28
Engine: L69 5.0L H.O.
Transmission: T-5 5 Speed
Axle/Gears: 3.73:1 Limited Slip Posi
i know 91-94 cavalier coupes have center console switches with driver auto down only
Old Aug 9, 2009 | 08:59 AM
Car: 1987 IROC Z
Originally Posted by 87350IROC
omni,
Well, I am looking for a single replacement switch that has autodown capabilities.
This is what I am NOT looking for
http://cgi.ebay.com/ebaymotors/97-98...Q5fAccessories
I need it to be separate switch, not 2 on one piece.
I need something like this, but in autodown format.
http://cgi.ebay.com/ebaymotors/POWER...Q5fAccessories
Old Aug 9, 2009 | 11:37 AM
Car: 1992 RS
Engine: Carbed 350
Wow - I'm dumb founded. I never tore the switch out of my 1997, I just looked at it from the top and assumed it was seperate switches - sorry dude! I thought I had it for ya with the 4th gen switches.
So what about the module shown above - I kinda like that thing, and it does auto up and down?
Old Aug 9, 2009 | 11:43 AM
87350IROC's Avatar
Car: 87' IROC
So you are set on replacing the stock switches? Just trying to figure out why the DEI module is not doing it for you?
Old Aug 9, 2009 | 11:24 PM
Car: 1987 IROC Z
Actually no.. I don't want to replace the stock switch...
Heres my idea.. I am going to ad a third switch to my window switches. This switch will be an auto-down switch, and will route to both of the existing switches.
Result : auto down for both windows simultaneously... with one switch.
I have an auto-down switch from a saturn SC that I was able to get working, and initially was to try to acquire 2 of them yet I believe that I can achieve the desired effect by routing one switch to both wires while leaving the stock switches intact . I just want a smaller switch and its likely that GM did not stray far from the 4 wire setup they have been using.
Old Aug 12, 2009 | 07:23 PM
Car: 1987 IROC Z
Should re-state, what late model GM vehicles had auto-down switches.
Old Aug 15, 2009 | 01:06 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I thought people used Saturn window switches.
Old Aug 15, 2009 | 02:15 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Try taking the duel one and take the passenger side apart and cut it down until it's flush. then mount it with a single hole by itself. you may be able to separate it completely, but that would have to be something you experiment with.
You may have problems with one window reaching the bottom before the other and then shutting off. IIRC, the shut off is triggered by the current draw when the motor reaches the bottom.
Old Aug 15, 2009 | 11:26 AM
Car: 1987 IROC Z
That is actually what I was going to do, but this switch is not aesthetically pleasing and i'd like something from a vehicle that has nicer switches. I am assuming that most GM's will work the same so I am just looking for something a little more congruent with the rest of the switches.
Old Aug 15, 2009 | 11:51 AM
Scorpner's Avatar
Engine: V6, V8
You could try to separate the auto-down portion of the switch and use that along with an original switch/es.
Old Aug 15, 2009 | 12:20 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i bought the DEI 530T works great look it up, auto up/down for both windows 45-60bucks
Old Aug 16, 2009 | 01:31 AM
Car: 1987 IROC Z
I know it makes sense to buy that bobby, I really do, but im just being hard headed. Does this thing just splice into your window switches harness ?
Old Aug 16, 2009 | 02:22 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
before you buy any switches, I'd do some more research. I'm not an expert but I don't believe its the window switch that makes it autodown. I believe there is a separate interior module (like the ECM for the engine) that controls all interior functions (locks, windows, a/c, lights, etc)....
Old Aug 16, 2009 | 02:28 AM
Bobby_80s's Avatar
Axle/Gears: no idea
yes its very easy to install 2-3 hours nly because you ned to take your time when dealinmg with wires and you need to take apart your console to get to the window swtiches and you need to wire directly to the battery(recommended)
but im very pleased with the result plusi get to keep my stock switches no fabricating
Old Aug 16, 2009 | 09:37 AM
Scorpner's Avatar
Engine: V6, V8
I was kind of wondering that as well, but had heard that they are in the same module. That would make things much easier to adapt.
Old Jan 30, 2011 | 11:42 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
The 1994 and older Chevrolet Astro van and GMC Safari van use window and door switches that are functionally identical and compatible with the wiring on the 1993 - 1997 F-Bodies. The only difference is the appearance of the rocker button. The single window and door lock switches are the same, just different removable bezels (so they can be used for either windows or door locks). The driver side window switch is a double switch, and the auto down function is compatible with the 4th gen F-Body.
I have a double window switch from a 1994 GMC Safari installed in my 1994 Camaro wiring harness, and three single switches for my passenger side window switch control and door locks. They all plugged directly in without modification and work perfectly. They don't match the appearance of the 4th gen switches, but work until correct switches can be sourced.
Old Jan 30, 2011 | 12:00 PM
BTW there is a power window control module, and it contains the solid state control and "express down relay", or auto down.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
luvofjah
Sep 3, 2015 07:08 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
