pulling headliner board, difficult??
Old Aug 12, 2009 | 06:38 PM
razman340's Avatar
Car: 1985 Z28
Engine: 305ci 4barrel
Transmission: 5-speed
my headliner fabric is hanging loose (85 Z28) and from what i understand, it is best to pull the entire headliner board out, clean off the old glue and foam, and replace with new foam and fabric. has anyone done this recently? is it difficult to remove the old headliner board? thanks, rick
Old Aug 14, 2009 | 07:03 PM
razman340's Avatar
Car: 1985 Z28
Re: pulling headliner board, difficult??
well, i pulled the headliner out of the car last night.........not TOO bad of a job to take on. some of the trim pieces and clips were a bit tricky. anyway, i took it to upholstery shop today and had it redone. they put all new foam backing on, and new fabric. this thing looks brand new!! i will try to get some pics up, rick
Old Aug 15, 2009 | 08:51 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
What did the apholstery shop charge for the redo? Was it a t top, or hard top?
Old Aug 15, 2009 | 09:32 PM
razman340's Avatar
Car: 1985 Z28
hard top car.......they charged me 85bucks. looks great. can't wait to get it back in the car, should be tomorrow. rick
Old Aug 15, 2009 | 09:41 PM
I've been going back and forth about what to do about my headliner. I did a thread about headliner repair, and found out some interesting options. I just want what ever I do for the fabric to be ten times stronger than what the factory put in it. I have a chunk missing from mine. If I could find an upholstery shop to do it for 85, I just might cave in and let them do it. I have a center council to screw with also.
Old Aug 15, 2009 | 10:43 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
My headliner board was really eaten away form the heat. It was cracking and really nasty. Ended up ordering one fron A1 auto. I doubt an upholstery shop could of helped me. But for 85$.. i shoulda tried at least. DArn it!!
Old Aug 16, 2009 | 07:08 AM
How did the replacement fit when you put the in?
Old Aug 17, 2009 | 10:42 AM
1Aauto's Avatar
Former Sponsor
Not sure how bad of a chunk is missing but this scrape and recover kit might be an option for you,if you didn't want to do the ABS one.
Camaro Scrape And Recover Headliner Kit
Old Aug 17, 2009 | 12:33 PM
Yes Tony, it may very well be an option. My interior color is called saddle brown, and the color is listed in the recover kit offered. I have seen the color "desert sand" in regard to other applications. Is it the same as saddle, or is it different?
Old Aug 17, 2009 | 01:43 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
https://www.thirdgen.org/ttops2
Old Aug 17, 2009 | 01:46 PM
1Aauto's Avatar
Former Sponsor
If you would like a free color sample to match it up. PM me with all of your info.Including email & pone# and I'll shoot it out to yah,so you can physically see the material.
T
Old Aug 17, 2009 | 02:22 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
I know you could do it cheaper but 85 bucks to have it done professionally is a good deal in my opinion.
Old Aug 18, 2009 | 12:17 PM
razman340's Avatar
Car: 1985 Z28
here is a pic of my headliner before re-installing it last night, it looks GREAT in the car.........in fact, it looks so good, that i am having my visors re-done now. rick
Old Aug 19, 2009 | 02:28 PM
Mudskunk's Avatar
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
after 20 years mine is starting to pooch down right in front of the passenger side seat belt. i will prolly re-do it next spring. pulling the board out isnt too bad i have done it on a different 3rd gen fbody helping a friend out. its getting the cloth and backing on in a professional looking manner that is difficult.
Old Aug 19, 2009 | 04:21 PM
razman340's Avatar
Car: 1985 Z28
yeah, pulling the board out wasn't too bad.....some of the clips can be alittle tricky, and i had to get a couple new clips from dealer. the key would be getting the pad and fabric back on, which is why i paid a professional to do that! LOL.......rick
Old Aug 22, 2009 | 05:42 PM
C.W's Avatar
C.W
How much will a crack in the board affect the scrape and glue kit?
Old Aug 28, 2009 | 09:00 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Axle/Gears: 2.77
It actually fit pretty good, except where the drivers side seat belt hole is. I should have cut out as little as possible. The plastic cover did not cover the hole completely and you can see the foam on the headliner. I hope i said that right!?
Old Aug 28, 2009 | 09:34 PM
basiccamaro's Avatar
I need to redo my headliner too. How do you get the interior trim pieces off to get started? I don't see any screw holes in the plastic A pillar/ceiling interior trim pieces. How do you get them off? Do they just "pop" off? My trim is pretty nice, I don't want to mess them up.
Old Aug 28, 2009 | 09:41 PM
Blue383's Avatar
who sells the headliner clips/fastners?
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 31, 2015 07:00 AM
zayne0
Aug 24, 2015 07:22 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
