Can I Replace This Bulb?
Old Aug 23, 2009 | 08:57 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi Guys,
So the AC/Heat controls aren't lighting up in my 86 maro, can I replace the bulb or is it a sealed deal? And if I can replace it does anyone know the bulb #. Couldn't find in on rockauto.com which usually has everything.
Alex
Old Aug 23, 2009 | 10:41 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Can I Replace This Bulb?
It's a single #194 bulb on the right side of the controller. First, remove the trim piece from around the radio and HVAC, then you can remove the screws and pull the controls out, but you may want to get under the passenger side to undo the cable to the heater door to make it easier to pull out the HVAC controls, that's just a push nut over a pin to hold the cable end on.
Old Aug 23, 2009 | 11:45 PM
Sweet, thanks for the great info. I love TGO!
Alex
Old Aug 24, 2009 | 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider a higher intensity 194 or perhaps a 194 LED replacement. Even then, however, the light probably won't be as helpful as we'd wish.
JamesC
Old Aug 24, 2009 | 10:25 AM
1Aauto's Avatar
Former Sponsor
Alex, you should be able to get one of those bulbs at Autozone.
Old Aug 24, 2009 | 11:41 AM
Thanks for the info guys. Is there any logical reason why Camaros have crappy lighting inside vs a Firebird. Cause my bird is way better lit, guess they just cheaped out? I'm gonna go LED for all the bulbs, hopefully I'll be able to live with it
Alex
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
