Third Gen/Fourth Gen Seatbelts
Old Sep 1, 2009 | 07:38 PM
tri power's Avatar
I was wondering if 4th gen seat belts will fit my 1985 transam front and rear.
Thanks for any help you can give me.
Old Sep 1, 2009 | 07:45 PM
eklipse38's Avatar
Re: Third Gen/Fourth Gen Seatbelts
yes they will work here is a write up i used when i did mine.
https://www.thirdgen.org/4thgenbelts
Old Sep 2, 2009 | 03:33 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
4th gen rear belts won't work in an 85' w/o cutting out the shoulder harness mount from an 89+ car and welding it in. An 85 only has lap belts in the rear.
Old Sep 5, 2009 | 07:51 PM
fernando rs's Avatar
Car: 1988 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 4TH. GEN. REAR
hey, think you can post up some pics of your install to see what it looks like.Im thinking of doing this myself. Cuz my seat belts dont lockup anymore
Old Sep 5, 2009 | 09:54 PM
mmm88TA's Avatar
Engine: 5.0 TPI
I did 4th gens up front but left my rear lap belts alone. There is a thread somewhere on here regarding retrofitting 4th gen rear belts.
Old Sep 7, 2009 | 03:38 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I've been told that the late 90's and earlier 2000 rear seat belts from a Cavalier will match the 4th gen belts really well.
Old Sep 7, 2009 | 08:24 AM
mmm88TA's Avatar
Engine: 5.0 TPI
Originally Posted by mmm88TA
I pulled recievers from late 90's early 2000's cavalier to match my front belts. I'm not sure how much of a stickler you are for things matching but this did the trick for me. These recievers were the same length as the stock ones and same button style.
just to clarify, when I used these recievers I had to pull from 2 different cavaliers (passenger side) because of the angle of the mounting bracket.
I can't get the pic to post but here's a link:
http://s274.photobucket.com/albums/j...cture115-1.jpg
*Note the angle on the mounting bracket for the reciever (pic is of 4th gen belts I had but the reciever's angles are the same)
EDIT: this is just for the recievers the belts themselves will not work
Racing Geek how'd your install turn out?
Old Sep 7, 2009 | 08:44 AM
Firebat's Avatar
There must be 2 different styles of 4th gen front belts. The ones I have won't fit into the thirdgen latch or receiver. My brother's LT1 belts would work but mine must be from an LS1 or 2001+ LS1. The metal prong on the belt is too wide. I have a simple solution to my problem, get the same style receivers.
Old Sep 7, 2009 | 09:01 AM
mmm88TA's Avatar
Engine: 5.0 TPI
yeah there are 2 styles, the belts I installed were from a 93' camaro. the rear buckles were wider then the 3rd gen ones, that's why I went w/ receivers from a cav.
Old Sep 7, 2009 | 10:59 AM
ssean92's Avatar
Car: sold
I used the ones from a 96 and modified them, worked out great.
Old Sep 7, 2009 | 06:37 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
FYI: This is a way to fix the "gaping hole" in the sill plate that is talked about in the link eklipse38 posted. I've repeatedly asked that my solution be added to that tech article, but my messages seem to fall on deaf ears.
My post is at the top of the page linked to below. You use 82-83 sill plates and they fit perfectly with the 4th gen belts. I posted a pic of my car with the sill plates and 4th gen belts. Took a couple of months to find some 82 sill plates, but got them for $6 for the pair at my local U-Pull-It.
https://www.thirdgen.org/forums/body...xterior-4.html
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
