Custom 1990 Dash For Autometer
Old Sep 20, 2009 | 11:17 PM
TwoBrakeTony's Avatar
Car: 1990 Camaro RS
Engine: SBC 350 w/ Holley 780cfm DP
Transmission: 700R4 w/ 2800rpm stall
Axle/Gears: Borg Warner 9 bolt 3.70 posi
Hello Camaro lovers,
I have searched everywhere for an aftermarket gauge cluster for a 90-92 Camaro, and no luck. So I'm making my own. I will show step by step of what/how I'm doing this.
I am modifying an stock gauge cluster from a 90-92 camaro. I took all the gauges, lights, and circuitry out of the white back plastic part of the cluster.
I traced the black middle plastic part of the cluster onto cardboard. I then cut and trimmed the cutout to fit in the face of the black plastic part. (I will later transfer this the cardboard cutout to a piece of Acrylic Sheet [plastic glass])
Going back to kindergarten! I got dimensions of the Autometer Gauges from Autometer.com and used a compass to draw out the size of the gauges. I took those to layout the gauges in cutout above.
I have yet to order the gauges, but hopefully next week I will have them and get things going. I'll keep post my progress.
Thanks.
Attached Thumbnails Custom 1990 Dash For Autometer-100_0582.jpg   Custom 1990 Dash For Autometer-100_0586.jpg   Custom 1990 Dash For Autometer-100_0587.jpg
Old Sep 20, 2009 | 11:25 PM
Car: 1990 Camaro RS
Re: Custom 1990 Dash For Autometer
More pics.
The Gauges I'm going with are The Autometer ES. The speedo and tach are 3 3/8'' and the oil, fuel, volt, and temp are 2 1/16''.
With the gauge template cutouts the blue is the hole that would need to be cut into the cluster, and the white is the bezel that goes around gauges.
And with using the stock gauge cluster I can use the clear plastic cover over the gauges.
This is how I am laying out my gauges.
Attached Thumbnails Custom 1990 Dash For Autometer-100_0588.jpg   Custom 1990 Dash For Autometer-100_0589.jpg   Custom 1990 Dash For Autometer-100_0592.jpg
Old Sep 20, 2009 | 11:34 PM
Car: 1990 Camaro RS
On the back white plastic piece of the stock cluster, it will need to be cut to fit the depth of the gauges.
Old Sep 26, 2009 | 06:34 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Something like this?
https://www.thirdgen.org/forums/elec...ry-gauges.html
Fitting the gauges in that space is tight,especially the bezels. The high beam indicator and directionals are from dennis kirk. They're for motorcycle dasboards. Not in the pic however are 2 red led's that I added for warning lights. One for low oil pressure and one for high engine temperature.
Old Sep 26, 2009 | 07:44 AM
one92rs's Avatar
Car: SOLD!!!!!
how did you hook up the warning led;s.
Old Sep 27, 2009 | 11:09 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
thanks for doing this. i plan to do it with 5 inchers, do you think they'd fit 1 5", 1 2-5/8" and another 5"?
Old Sep 28, 2009 | 01:12 AM
Car: 1990 Camaro RS
I'll make some cut outs and post the pics and let you know.
Old Sep 28, 2009 | 04:31 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
You can get instrument clusters from Hawks third gen for the Camaro.
http://www.hawksthirdgenparts.com/gaugepanels.aspx
Old Sep 29, 2009 | 03:56 AM
Car: 1990 Camaro RS
You cant get anything that fits round gauges for 90-92 Camaros.
Old Oct 5, 2009 | 08:10 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Hey everyone I just wanted to put some input in on the way I am doing mine. I bought a set of Cyberdyne digital gauges to put in it. What I did is removed the plastic trim around the gauges and put a piece of cardboard on the front and then fiberglassed behind it. I'm currently in the process of triming it down and when I get the chance I will lay a coat of fiberglass filler on it and sand it smooth then cut my wholes out and mount the gauges.
Old Oct 13, 2009 | 11:13 AM
73duster's Avatar
I'm gonna try the same thing. I just ordered a used cluster to hack apart. Please post more pics and progress reports. Also, can i wire up the gauges to the connector where the cluster plugs in to. Does anyone have a schematic showing what feeds what gauge? Can i just wire up using an electronic speedo to where the stock one gets its feed? What about the fuel gauge? 0-90 ohm?
Old Oct 13, 2009 | 05:45 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
most electric speedos from autometer can be connected to stock, you have to calibrate it by driving a certain known distance. fuel for most GM cars and for our camaro is 0-90 ohm. do you have a wiring diagram in your haynes, chilton, or autozone.com repair manual, i would think they'd have the cluster, if not search the board for the colors. you may want to run new sensors for water temp/oil pressure
Old Oct 13, 2009 | 09:05 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Subscribing. I am very interested.
Old Oct 13, 2009 | 09:37 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
lookin' good. very simliar to my second attempt at putting aftermarket gauges in this dash.
i hate to burst your bubble on one thing though: the thickness of the bezels on the autometers will not allow you to put the clear plastic back over them. you'll have to run without that part.
Old Oct 15, 2009 | 08:02 AM
remltr's Avatar
I got a low oil pressure switch( tee'd off the opsu on the back of the block) and high temp switch from autometer. Oil is on below 15 psi and temp light goes on over 200(I'm running a carb)
Old Oct 15, 2009 | 11:23 AM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Greg from Covans classic dash is now in the process of finally making the custom panel for 90-92 Camaros to fit custom guages like Autometer after I begged him to and told him there was a market for it, call him @ 866-882-3525 he is making it in factory black matte, brushed aluminum, and Carbon Fiber. Spread the word please,
Mike S
91' RS swapping 2010 L99 A6
Old Oct 15, 2009 | 02:28 PM
mw66nova's Avatar
Engine: 7.0L
i'm glad to hear that! i'd love a better looking panel that allows for a more finished look. don't get me wrong, some of these look great, and mine isn't bad either, but the end result still looks home made.
Old Oct 15, 2009 | 06:45 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Just looked at Covan's Classic Dash he isn't advertising anything yet for a third gen, but the stuff he has already is really expensive. 200 bucks for an undrilled blank panel.
Old Oct 15, 2009 | 11:43 PM
Engine: L99 L98
he just started production, it will be about 6 weeks before they are finished.
Greg @ Covans Classics Dash
Old Jan 15, 2010 | 01:17 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Does he have a website...if so can you post it?
Old Jan 15, 2010 | 02:42 PM
RU1NER's Avatar
Google Covan Classics
Old Jan 26, 2010 | 10:58 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Lets keep this thread going cause I just started one of my own after not finding this very answer. How to install 5" autometer Tach and Speedo into the stock locations? Hope yours turns out well, and pics pics PICS!!. Here's my thread btw for people interested in the pre 90 cluster:
https://www.thirdgen.org/forums/fabr...u-install.html
Old Feb 5, 2010 | 01:39 AM
vonkysmeed's Avatar
as you stated, it is Pre 1990. That is fairly easy with the double hole dash. The flat plate adds to the degree of difficulty. If there was a custom panel, I would use it. I may post my own build once I am done with my pinto.
Old Feb 5, 2010 | 02:00 AM
exarkun1178's Avatar
if i bought individual gauges, would they simply mate up with stock wire harness?
Old Feb 5, 2010 | 06:55 AM
mw66nova's Avatar
Engine: 7.0L
no. and the ohm values for the gauges will likely not match your sending units for the factory gauges (except the fuel level gauge, get a 0-90ohm gauge and use the factory wiring).
most folks just run new wires, or better yet, get mechanical gauges with mechanical senders...much more accurate that way.
Old Feb 9, 2010 | 02:50 AM
vonkysmeed's Avatar
The electronic gauges I bought came with their own senders. Replace the senders with the new ones and use the same wires as stock. Keep the stock look and no one is the wiser. Mechanical is a PITA due to the need to run the lead from the block to the gauge (sender is in the gauge)
Old Feb 9, 2010 | 08:15 AM
sorry is this sounds stupid... do they include instructions on how to do this? my dash is.... gone. and i have no interest in putting it back in.
Attached Thumbnails Custom 1990 Dash For Autometer-camaro-dash-board-2
Old Feb 9, 2010 | 08:20 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
does anyone know the status of the panel that greg was making in october? id really like to get one
Old Feb 9, 2010 | 05:35 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
I am trying this too. I was thinking about fiberglassing around a stock one and mounting my dakota digital gauges. I am also toying with the idea of selling my digital tach and trying to see if magden would make me something
Old Feb 25, 2010 | 09:54 AM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Subscribing..
Old Feb 25, 2010 | 12:04 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
Classic Industries has a gauge panel. here is the link. its on page 25.
http://downloads.classicindustries.c...df/C_SEC_D.pdf
Old Mar 1, 2010 | 10:08 AM
vonkysmeed's Avatar
is there one for 90-92? Only see the one for 82-89
Old Apr 1, 2010 | 09:28 AM
Axle/Gears: stock
There are a few that are starting to be created, but the reason people are making their own is cause their isnt one. Im finishing mine as my spring break project. I have to get a dual guage pillar cause i can only fit 4 gauges on it
Old Apr 1, 2010 | 09:51 AM
Engine: L99 L98
covans classic dash is making it now, contact them to see if they are finished with it.
Search Google " Covans Classic Dash"
Old Apr 3, 2010 | 09:22 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I did pretty much the same thing, only i didnt hack apart my stock cluster. I took a flat sheet, and made curved side panels and a top to mimic the clear plastic of the stocker and to fill in the gaps. and then just welded tabs for the stock mounting locations.
Old Apr 5, 2010 | 09:48 AM
Engine: L99 L98
post some pics please, would like to see it
Old Jul 9, 2010 | 03:03 PM
Engine: L99 L98
here it is boys, thank Greg @ Covans classic dash, spread the word cause they have a lot of $ in R&D building this thing
http://www.classicdash.com/shopping/...-1992/Drilled/
Engine: L99 L98
spread the word
Old Jul 9, 2010 | 03:04 PM
Engine: L99 L98
90-92 the only one made
Old Jul 9, 2010 | 03:05 PM
Engine: L99 L98
90-92 dash
Old Jul 9, 2010 | 03:06 PM
Engine: L99 L98
here it is spread the word
Old Jul 9, 2010 | 03:07 PM
  #42
Engine: L99 L98
its finished
Old Jul 9, 2010 | 03:08 PM
  #43
Engine: L99 L98
90-92
Old Jul 9, 2010 | 03:09 PM
  #44
Engine: L99 L98
Old Sep 4, 2010 | 12:01 PM
  #45
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Bringing this one back from the dead. TwoBrakeTony, what does your finished product look like? I'm getting ready to do mine with Autometer Cobalt digital gauges on my 92. I'm concerned that all 6 gauges won't fit in the cluster. Speedo and Tach are 3 3/8" and all the others are 2 1/16".
Old Sep 8, 2010 | 07:57 PM
  #46
Engine: L99 L98
have you seen the link i posted?
Old Sep 8, 2010 | 08:04 PM
  #47
pwdbychevy's Avatar
Yeah I saw them. Kind of expensive. I'm making my own.
Old Sep 13, 2010 | 02:48 PM
  #48
vonkysmeed's Avatar
If you are using theirs, check your sizes. The spedo and tach are 5", not 3-3/8.
Old Sep 13, 2010 | 05:24 PM
  #49
pwdbychevy's Avatar
Cobalt digital speedo and tach sizes are 3 3/8". Im not using their stuff. Im making my own panels. See pics above
Old Sep 13, 2010 | 10:24 PM
  #50
Engine: 355 chev
pwdbychevy, what size are your holes you have cut?
