Remove dash and install LEDs. [need help]
Old Sep 29, 2009 | 06:29 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Well I have followed this "How-to" :
https://www.thirdgen.org/leddash
I have removed the 8 bolts infront, lowered the steering wheel ½ inch
and removed the 2 lower 10mm bolts.
But I cannot pull it out and reach the speedo wire ?
How to remove it in the best way, I dont wanna break anything, please help me
Old Sep 29, 2009 | 06:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Remove dash and install LEDs. [need help]
You'll have to release the speedo clip, which holds the speedo in place, from underneath the dash. A flash light and long-bladed flat screw driver are recommended.
JamesC
Old Sep 29, 2009 | 09:14 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Hope this helps, I took a pic of the clip so you have some kind of idea of what you're trying to do. You need to push down on one side so that the end of the cable will clear. The clip sits at an angle and grips the cable. The tab should be located near the bottom and offset towards the drivers side. Or the seven O'clock position if you are facing the speedometer.
Old Sep 30, 2009 | 08:14 AM
Theking's Avatar
Car: 1989 IROC-Z
Thanks for the response, Is it easy to remove and attatch it again ? The wire ?
Is it easy to break it ? Cause I dont wanna lose the speedometer, and do I need to adjust something to get the correct speed after removing and putting the wire back ?
Or is it impossible to change the speedometer "setting" when removing the wire ?
Cheers
Old Sep 30, 2009 | 08:20 AM
kimnach's Avatar
Car: 1988 iroc-z (original owner)
Transmission: 5-speed manual
one other thing you should do is remove the two screws holding the fuse block in place. i found that reaching up to reattach the speedo is much easier with the fuse block slightly moved out of the way.
Old Sep 30, 2009 | 08:21 AM
JamesC's Avatar
Or is it impossible to change the speedometer "setting" when removing the wire?
Easy to remove and reattach, yes. No problem with breakage unless you somehow happen to break/damage the speedo needle with a heavy hand. There is no adjustment afterward. Plug and play.
Here's a bit more info:
https://www.thirdgen.org/forums/tech...-problems.html
JamesC
Old Dec 5, 2009 | 11:05 AM
Theking's Avatar
Car: 1989 IROC-Z
Change done
Installed LEDs in the dash, Shifter indicator and AC controlls.
Also installed White Strong LEDs in the roof, floor and backviewmirror.
Here is some pictures :
Old Dec 5, 2009 | 11:25 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Looks good!!
Old Dec 5, 2009 | 11:56 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Good job there. Looks just like mine after I swapped in LED lights. I especially enjoyed more light on the climate controls and the console to better see the gear selection.
Old Dec 5, 2009 | 12:35 PM
IrocZ'85's Avatar
Car: '85 IrocZ
Looks just like mine as well! Very nice job.
Old Dec 5, 2009 | 01:42 PM
Coyotesa's Avatar
Car: 1987 Trans Am WS6
Engine: 305 tpi
That picture would make a great background!
-Buddy-
Old Dec 5, 2009 | 01:58 PM
Awesome-X's Avatar
Car: 87 Camaro
Your dash lights look amazing and I know this has problably been asked to death but where did you buy your LEDs and what color are they?
Old Dec 5, 2009 | 02:20 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Damm good job bro! Hey I didnt know there was lights by the doors, I wonder if mine has it. Did you also change the light under neath the dash by the cigarett lighter or so?
Tony.
Old Dec 5, 2009 | 02:49 PM
Theking's Avatar
Car: 1989 IROC-Z
Originally Posted by Coyotesa
http://theking.joakimweb.se/z28/gfx/leds.jpg
-Buddy-
Thanks man
I can upload a 1024x764 with my homepage adress faded into it for use as background, If you where asking for a larger one
The LED color is Blue on the Gauge, Tranny indicator and AC Controll
And the Floor, roof and rearmirror have super bright white ones for good lightning.
LEDs can be bought from superbrightleds.com in US for the friends over seas :-) In sweden you can buy these kit thru me.
Tony.
I Changed the dash, shiftlight, ac controll to blue and the roof, floor (driver and passengerside) and rearviewmirror to superbright white ones
Here is some install pictures (the roof,floor,rearmirror ones I soldered and made myself)
Homemade 12 LED (white) 20.000mcd. [ROOF]
Rearmirror 1 LED on each side (white) 30.000mcd [MIRROR]
Floor LEDs 1 on each side (driver/passenger) Wide Angle 15.000mcd [FLOOR]
Old Dec 5, 2009 | 03:26 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Tony.
I knew some cars had lights by the door but I never knew my car did until a couple days ago when I took an old (not working) alarm system out of my car. It uncluttered the engine bay A LOT, it made me feel safer knowing the wiring is butchered any more, and I was able to shorten a lot of it so there is less wiring in general. I probably saved an easy 5 pounds from all the crap I took out. Do the lights by the doors have a lens that goes over them? I don't have any lens.
I don't think I have a light under the dash but maybe I do and I just don't know it yet. lol
How bad would it look, or how bright would it be if I just used the white LED's everywhere? My car is red with black interior and I doubt the red LED will match the stock dark red paint.
Mike
Old Dec 5, 2009 | 08:16 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
I did a red LED conversion in my Z car. Looks pretty good at night there are a few high spots but im fixing those tomorrow. I could take a few pics to show you guys if you like. I'm planning on using blue LEDs in my camaro I just havent gotten to that point in her break in to warrant tearing the interior apart...again. My Z car I'm planning on a red and black paint scheme so the red LEDs help (that and I needed the practice for my camaro lol).
Old Dec 7, 2009 | 07:23 AM
Awesome-X's Avatar
Car: 87 Camaro
Wow your roof one is awesome! I wish you lived in the US so we could buy stuff like that from you lol. And by all means anyone with LEDs in their car should post pics, they make our cars look 100x better on the inside.
Old Dec 7, 2009 | 07:50 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
You can even dim the things using a PWM circuit. If you get some really bright ones and you would like them a little dimmer. Nice explination including diagram of the circuit here.
http://www.reuk.co.uk/LED-Dimmer-Circuit.htm
It would require you to move the dimming wires from the headlight switch to the PWM circuit however to make it work. However I do not think it would really be all that hard. Just stick another little **** in the dash
Old Dec 7, 2009 | 07:58 AM
JamesC's Avatar
Here's a link that provides some info and pics:
https://www.thirdgen.org/forums/inte...-overhead.html
JamesC
Old Dec 7, 2009 | 05:15 PM
Engine: 3.0L 2JZGE
Damm your interior looks good at night I bet.
Tony.
Old Dec 7, 2009 | 05:35 PM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
are these's just plug and play? anyone have a pic of a 90-92 dash, and color, prefer with or blue tho
Old Dec 7, 2009 | 05:37 PM
Engine: 3.0L 2JZGE
Yeah seriously I seen everyone modding the older years but what about the 91-92's?
Tony.
Old Dec 7, 2009 | 09:38 PM
87_Injected's Avatar
Car: 2010 2LT RS
That looks sick! I may end up doing that down the road.
Old Dec 13, 2009 | 08:00 PM
92Z28 AZ's Avatar
Engine: 5.7 Roller w/ Trickflow
Transmission: M5
I need to do this for sure....I have a 92 and would like to see pics first.
Old Dec 21, 2009 | 10:42 PM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
dude after seeing this when i rip my dash out im gonna have to do that to mine, it might just be me but that looks better than some of the digital dashes ive seen
Old Dec 22, 2009 | 04:19 AM
z28 TPI's Avatar
I know of a website called hidplanet.com that explains the PWM circuit in detail. Truth be told I'm working on converting this http://www.youtube.com/watch?v=K6sZg...eature=related to work on my Z i'm almost done with working out the schematics but it will be a while to build. I'm working on making something similar for a 240sx, custom lights, and custom tailight lenses. To put these lights into the dash of any car isn't that hard what's the hard part is the overall look you are trying to achieve. 91-92 dashes should be to hard. I will take pictures of my Z to show you all. Fortunately for my Z there was already a PWM circuit built into the instrument lamp circuit of the dash. Doesn't mean I dont understand it its just I got lucky. As far as the PWM circuit you could just use the dashes dimmer you would just need to run the right resistors in series to the leds in order for them to work. The PWM circuit just makes it a lot easier to run them with the attached resistors also gives the driver a little insurance on the amount of work needed to put them in. There is also some other goodies that this led god has done that I want to put on my cars I just need time. His name is azdave on the hidplanet forums and I do mean that this guy is a god when it comes to leds and he is cool on answering questions.
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
