cruise control problems
Old Sep 29, 2009 | 08:50 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
My car is in park. My dad accidentally put the cruise control on. I pressed the cruise control reset button and my cruise control surges to 7000 RPM red zone. I shut it off immediately. it never did that before. my idle also went up to 1500-2000 RPM
i think it could be a vacuum leak. i just had my motor mounts replaced
it never did this before
Old Sep 30, 2009 | 01:52 AM
Richwiz1's Avatar
Re: cruise control problems
Check yourlines going to your vacuam canister should be around ball looking thing close to your charcol cannistermay be mounted in wheelwell towords front of car I think thats where mines at lost the first one it fell off.
Old Sep 30, 2009 | 05:51 AM
KITT1983's Avatar
I am confused with your post
BTW Thanks, I will look by my Cruise Control Vacuum Diaphragm (round ball looking thingy) and it is by the charcoal canister
Old Sep 30, 2009 | 07:13 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
'82-83 has electro-mechanical cruise control. It runs off the speedometer cable, some electric switches and vacuum for the throttle cable servo. I would suspect something is wrong with the cruise control tranducer unit on the driver's side inner fender.
The is no round ball vacuum canister. That was used on the '84-up electronic cruise control.
Old Sep 30, 2009 | 12:46 PM
Richwiz1's Avatar
Sorry if I confused you but you said you thought it might be a vacuam leak. I have a 91 Z28. Looking at my haynes book I tend to agre with the other guy.
Old Sep 30, 2009 | 01:42 PM
KITT1983's Avatar
what is the cruise control tranducer unit ? how do I check and fix it?
Old Oct 7, 2009 | 07:03 AM
KITT1983's Avatar
bump
Old Oct 14, 2009 | 11:58 AM
KITT1983's Avatar
after further looking into the problem. my cruise control throttle cable has a kink in it. the problem of the RPM surging and high idle on cold start up was still there. but when I disconnected the power cable to the cruise control transducer the high idle disappeared
I think it is the cruise control transducer and i have to replace cruise control throttle cable
Old Oct 14, 2009 | 06:35 PM
KITT1983's Avatar
the speedometer cable is missing
Old Oct 16, 2009 | 05:11 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
my cruise control took control of my ride, sent me 70mph down a 34 mph zone. disconnected that bad boy
Old Oct 20, 2009 | 06:55 PM
KITT1983's Avatar
bump
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
