How to get door panles flat..UPDATE: it works!
Old Oct 8, 2009 | 10:05 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
My car has been sitting in it's box for the last 6 years..getting back on it's feet... after cleaning the out side..(Dusty)
i was looking at the inside..and noticed that my door panle on the drivers side looks sorta wrinkly? like it was damp..still smells new.. but looks like it got Wet? the pass side is fine..
how would i go about getting the bottom 5" of door panl flat..
will post photos.. anybody seen this before..
thinking..take them off apply steam and press flat..but wanted to ask first
thanks
Old Oct 9, 2009 | 02:13 AM
Awesome-X's Avatar
Car: 87 Camaro
Re: How to get door panles flat? anybody
Mine are like that too, but the door panel is torn from the plastic pins that are pressed into the door. Camaro door panels are the most fragile panels I've ever seen
Old Oct 9, 2009 | 10:59 AM
mikeyg785's Avatar
Car: 1986 camaro iroc z28
Engine: 305 tpi
Axle/Gears: stock 2.23
i have that same problem from the windows leaking. unfortunately theres nothing you can do to it since its warped. thats like trying to flatten out a piece of cardboard thats wrinkled from sitting out in the rain. even though im very sure theres nothing you can do to fix it i would love to hear what u did if u do find a way.
Old Oct 9, 2009 | 11:03 AM
mikeyg785's Avatar
Engine: 305 tpi
btw if u try steaming the panel i could see that helping or doing a small bit of harm so you might as well try it since its already wavy.
Old Oct 9, 2009 | 11:05 AM
mikeyg785's Avatar
Engine: 305 tpi
o ya 1 more thing. when you take the door panel off i found it helps alot if u stick a flat head in between the plastic pins and the door to take them off without ripping the panel. just be careful to try not to scratch up the door to much,
Old Oct 9, 2009 | 01:19 PM
ya..i know about how they can be a pain to take them off..
what is that stuff thick Paper?
Old Oct 9, 2009 | 01:35 PM
captbarbosa's Avatar
The panels on my 90 bird were wavy, and the previous owner had already tossed them, but when I got the car, I took them anyway.
I cut a thin piece of paneling (yeah) that fit the door panel (on the back side) where it was wavy. 3M'ed the crap out of it with contact glue, set a piece of plywood on it with a couple of concrete blocks to keep it flat.
Dumb as all this sounds, the panels came out flat as new.
What the heck...couldn't make 'em worse!
Old Oct 9, 2009 | 01:44 PM
.kewl..sounds like it would work also..
im Just PEEVED i have a wrinkle..
Old Oct 9, 2009 | 01:56 PM
1Aauto's Avatar
Former Sponsor
If you break those little plastic tree pins off the door panel.I'm pretty sure that I've seen them in Autozone.
But yah if you take the panel off carefully use a flat head screw driver, and it'll help from breaking them.
Old Oct 9, 2009 | 02:35 PM
mikeyg785's Avatar
Engine: 305 tpi
though what the other guy said is kinda weird i would definatley try it. its worth it since getting a new panel is 170(where i checked). and yes the pins are fairly easy to get.
Old Oct 9, 2009 | 05:36 PM
$170 for a new one?? is it a GM part.. whats the place...
if i could just Buy a new one..ill do that.. and fix my old one for a back up..
Old Oct 10, 2009 | 08:16 AM
mikeyg785's Avatar
Engine: 305 tpi
the site is ecklerscamaro.com. its a sight i used a few times and i recommend it. however you do have to assemble the panel but i think it comes with all the stuff. also im pretty sure its not a gm part or they would say it is or its a company certified by gm but a couple of the parts i got werent gm certified and they worked great.
heres a link to the three panels
http://www.ecklerscamaro.com/dept.as...d=1665&level=2
Old Oct 10, 2009 | 12:16 PM
thanks for the link.. i took a look they are out of the one i need.. will have to get mine Fixed...this sucks..
Old Oct 10, 2009 | 12:56 PM
mikeyg785's Avatar
Engine: 305 tpi
haha i typed a post then went to eat breakfast a while ago but forgot to click submit post so i just copied and pasted it because it wouldnt let me put the original one up but anyway..................wow i just found this, im not sure what it includes but you might wanna find out becuase if it includes paper an fabric that a great deal compared to 179 and you know its a gm or gm certified product.
http://www.trademotion.com/partlocat...=2&catalogid=2
Old Oct 10, 2009 | 01:04 PM
mikeyg785's Avatar
Engine: 305 tpi
if they're out of your red interior, which im assuming is the problem and they dont have the you wanted, since the panel comes unassembled you could carefully remove the red fabric from your old panel and put it on the new one(if you dont mind wasting the new fabric)
Old Oct 10, 2009 | 01:37 PM
it's only money..(do not look at the 7 years of dust) on the rockers.
see this is what im talking about..I Hate it!!.. the car still smells new.
yes i always keet the mats coverd as well.. (towls) thats why the inside is still new.. sep for the new wrinkles Name:  Z28035.jpg
what do you think? remove.. steam..and press flate..let sit for a week then see?
Old Oct 10, 2009 | 08:11 PM
mikeyg785's Avatar
Engine: 305 tpi
yep thats what i figured but mine look 5 times worse. i say maybe try it and see what happens. i dont think it would get it 100% better try it and then i was thinking throw the flat side of the cynder block on it do keep it pressed flat. or you could do what the other guy said if it works but it would b more work.
Old Oct 10, 2009 | 08:14 PM
mikeyg785's Avatar
Engine: 305 tpi
make sure MAKE SURE you know that the leaks are sealed and it wont happen again. the only thing that could cause that is leaks or maybe extreme humididty.
Old Oct 10, 2009 | 08:35 PM
that's what i was thinking..it's always been inside..but the small shop it was in.. is not sealed verry well.. 2" in gap under the door..
the trunk was unlocked for 2 years..of the 6 it's been setting and last year we had 5' of snow... this is what i get for not checking on it..
Old Oct 10, 2009 | 10:03 PM
mikeyg785's Avatar
Engine: 305 tpi
im just speaking weatherstripping. i keep mine out side so what i do is go outside and sit in the car to find any leaks in the weatherstripping. im going to post a pic of my panel so u can c how fortunate u actually are lol
Old Oct 11, 2009 | 09:16 PM
Donald87FB's Avatar
Car: 93 firebird formula
Engine: 350 Lt-1
wow and i thought mine were in decent shape. the material on mine are all riped and there is a stain on the drivers side that looks like rust puke..... but i need to find out where they sell the window trim on the exterior. i fixed mine up a little, but the middle gets wet because water is getting inside the door.
Old Oct 11, 2009 | 09:28 PM
mikeyg785's Avatar
Engine: 305 tpi
if your talking about the weatherstripping, you can get it off ecklerscamaro.com for 60 both doors and its relatively easy to install. the longest part for me was taking the first door panel off lolz.
Old Oct 11, 2009 | 09:30 PM
mikeyg785's Avatar
Engine: 305 tpi
0.0 i didnt notice u had a firebird. im sure it still be easy enough to find and the same price
Old Oct 11, 2009 | 09:48 PM
Donald87FB's Avatar
Engine: 350 Lt-1
hey its cool, yea i had fun with my door pannels today too, took me way longer than i thought. made me feel dumb. but its true they must be made from paper. sooo brittle. the plastic is too, on the top. i broke it. and there is retarted staples that hold the inside strip to the panel. so i got one off, the other is still attached to the broken part and i think new pannels for me is the way to go.
Old Oct 11, 2009 | 11:36 PM
only my driver side has the wrinkle.. ill be getting mine off and doing the steam and press flat for 4 day thing..
for now one when my car is stored..it's the airtight car bag for me..
after all..i will never let my car sit like that a 2nd time...
Old Oct 12, 2009 | 02:12 PM
mikeyg785's Avatar
Engine: 305 tpi
ya its always bad for things to go unused like that for so long. things like the ac compressor can go bad just from not being turned. (not sure if its the compressor i forget. i know its the part with the wheel that has a belt attaching it to the engine.)
Old Oct 14, 2009 | 11:20 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Actually the paneling idea is not a bad one. The only think I would do is treat it with something because if it gets wet, paneling warps too. I think its a good alternative though, especially if the panels are really bad.
Kevin
Old Oct 14, 2009 | 08:15 PM
mikeyg785's Avatar
Engine: 305 tpi
lol mine were broken when i got the car so i didnt have to worry about that it made it alot easier to take off and put them on.
Old Oct 21, 2009 | 04:10 PM
mikeyg785's Avatar
Engine: 305 tpi
so did u try to steam thing yet?
Old Oct 21, 2009 | 04:38 PM
no i have not tryed to even take them off yet.. but it's in the plans.
did buy some larg clamps and 3/4" plywood to clamp it all flat when i do. i will take photos from start to finnish..to show the out come..plywood will be in plastic when clamped to Door panles.
just payed for the new eng today $3200 for the short block shipped
dart block
11.4.1
all forged H beam rods
forged crank
427 CID
sending them all my parts to turn it into a long block +
my parts
accel supper ram (1000cfm)
36lb ijtrs
sportsmen NOS Foger (180 HP hit)
mech roller cam 236/242 @50 602/608lift (small street cam)
AFR Heads 220+ Runners
fluid damp
flex plat
oild pan (Milidon8 qt)
Pete jackson GD (you cant hear it) i like it that way.
iv been bissy .... as soon as all the other stuff is done (orderd)i can start on the doors
they tell me 5 to 8 weeks for the eng.. in that down time starts from today..
i start all this other stuff... had to buy a new battery last night optima ($170) my last optima was brand new only 3 moths old..when the car broke 7 years ago...LOL.. and it did not live just sitting the last few years... this is the nickle and dime stuff i hate!!! my old optima is still in the shrink wrap.....3 months old..and im getting $9.00 for it..core..LOL
Old Nov 26, 2009 | 08:56 PM
OK UPDATE: ***IT WORKS!!!***
picked up 2 1"x6" x8' PLANKS of ceader (cheap stuff)
also picked up some 6" C clamps. and 2 of them wood clamps 10"
forget what they are called.
total cost for tool's $25.00 thats every thing!
even the tool to remove the panles from the door's this is a must have tool if your going to do this Job.
total time in work 1hr
let sit and dry 24hrs+ it's up to you.. on that part.. but they are like brand new!!
cut the planks to size. test fit..
got all the tools set up..
stripped the door panles down (taking off all the plastic pegs)you lift and twist and they turn out.. keep them to reinstall the panle..i took them out to make the panle.
close to flat. for clamping.. you could clamp all the panle it self. if you wanted to.
now how to get the door panles wet on the side's/end's i need them wet. and how far in..Huumm..!Bath tube! so i filled the bath tube with about 6" of Hot water.
let the panel's sides i needed wet. sit in the water for about 2 min ea end.
remove most of the water from the panle with a bath towle
i layed a towle over the panle and set them up in the planks and prest most of the water out.. i them removed the planks and reset the panles up in the planks and prest them tight and flat!
(see just above..you can see the plank of wood pressing in from the back)
now after clamping them together tight and flat!.. let them set in a warm room for 24hrs or as long as you like..i put them in the top floor of my house in a room set at 75 on the tstat.
then after dinner today i came back home. and took the clamps off. and this is what they look like now! (also let them sit in the room with clamps off close to a heater so they stay warm..)
100% brand new!! nice and flat set to be installed no more Sag's or winkles.at all!
Old Nov 26, 2009 | 09:09 PM
could not have Come out better.. i also found the leak. that got them wet to start with.. thats been fixed.. and now i will install it back in the car. in the nexed few days...IT'S AS FLAT as the day the car was made!
and this time i will not let the car site for years at a time.
Old Nov 27, 2009 | 08:08 AM
Awesome-X's Avatar
Car: 87 Camaro
Re: How to get door panles flat..UPDATE: it works!
Wow thats pretty crazy...very nice idea.
Old Nov 27, 2009 | 10:50 AM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
freakin awesome i would get nervous about ruining the backing material though
Old Nov 27, 2009 | 04:17 PM
nothing to worry about.. take a look at the photos. look at the top photos at the start..
came out like new.. and the nice thing is if you need to clean them you can do it at the same time.. then clamp them up to dry.
remember: i have 1"x6" planks on the inside and out side of the door panle.
(front and back)
(did not show a shot of the back side of the panle.) but. in one of the photos you cant just see the wood plank at the end of the door panle..
your pressing the damp panle with the wood planks and clamps..
Old Jan 13, 2010 | 08:01 PM
mikeyg785's Avatar
Engine: 305 tpi
oh man these look awesome! i cant wait to do this to mine. did you put the panels in the tub with the fabric on?
Old Jan 13, 2010 | 08:11 PM
yes.. just a fast dip lasting about 8 to 10 sec.towle off the exs water then clamp them up and let them sit.. takes just a day. to dry.. then remove clamps and let dry over night.. then re install.
the white plastic pegs just twist out. and remember to mark your lower black rubber sweep i use a flet tip marker. so i remember what side faces what..and placement.
remember: you use planks on the front and back of the door panle..
look at the photos close.. it's easy and sorta fun.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
