Custom dash wiring help needed.
Old Dec 16, 2009 | 07:53 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hey guys,
Just wondering if anyone has a wiring diagram for the dash in a 1985 trans am?
I need to know what wires etc i need to keep and what can be taken out to clean it up.
as you can see the car has been converted to Right hand drive, and they just cut it and glued /soldered everything back together, but that bits fine i really just need to know the purpose of each of the dash wires going into the connectors below:
Old Dec 17, 2009 | 08:45 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Custom dash wiring help needed.
Old Dec 19, 2009 | 02:37 AM
evilstuie's Avatar
thanks for that.
That should be enough to get me going.
The idiot that did the right hand drive conversion pop rivetted the hvac unit to the firewall. so i now have to break it to remove it.
Old Dec 19, 2009 | 03:18 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
drill the pop rivets and save the unit
Jorlain
Aug 24, 2022 05:11 PM
z28_AJ
Aug 27, 2015 08:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
stalkier
Aug 13, 2015 12:59 PM
