May be pulling dash soon
Old Dec 28, 2009 | 02:43 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
I will probably be pulling my dash completely out very soon and replacing it with the one out of my 89 parts car. Im looking for any tips and suggestions to look into while doing this?
im trying to get rid of the hack job left by some of the custom work done in the 80's, such as where the tv and vcr used to be
Again, Thanks for all the help!!
Old Dec 28, 2009 | 03:20 PM
Steve86TA's Avatar
Car: To many to list
Re: May be pulling dash soon
if you have never pulled a dash before... take your time. It may not be a bad idea to mark some of the plugs with what they go to , although most of them are idiot proof plugs..Not a hard job just a little time consuming
Old Dec 28, 2009 | 05:59 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
take your time. its easy to get it out just watch out for all the wires and where they mount to the dash. it also helps to lower or remove the steering column.
Old Dec 28, 2009 | 06:18 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
VCR?
Old Dec 28, 2009 | 06:25 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I just pulled mine last week. Take your time. It can take a few hours.
I used small ziplock bags to sort and label each group of nuts and bolts. Then I tagged every electrical connection to make them easier to find again and connect.
Old Dec 28, 2009 | 07:11 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
just went and checked out the dash in my parts car. and wouldnt you know its got a quarter sized hole on the vertical panel where the center vents are. any creative wat to cover this anyone? its still in better condition than mine!
yes vcr! haha all the passenger side ac ducting is cut out and duct taped off to make room for the 1986 television also! haha
Old Dec 28, 2009 | 10:26 PM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
I'm pulling the dash out of my 1985 Trans-AM for my ground up restoration. I'm doing things the same way. I'll probably be replacing much of the wiring as I'll be switching to electronic gauges and hopefully a digital dash. (Assuming I can find one in good working order.)
Old Dec 28, 2009 | 10:57 PM
ShMaCk2004's Avatar
what ghetto did you get this car from?
Old Dec 28, 2009 | 11:53 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
To fix those holes I would use some fiberglass cloth to cover em, prime it and repaint it, you should never notice it.
Old Dec 29, 2009 | 12:34 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
maybe if i could find something like this in a decent carbon fiber finish
any ideas????
Old Dec 29, 2009 | 12:52 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I don't really like the woodgrain, lets leave that for buicks and caddilacs.
Carbon fiber may look good, post pics if you do it.
Best of luck-
Eric
Old Dec 29, 2009 | 12:55 AM
Engine: 305TPI
Best of luck-
Eric
Given that the "wood" isn't really wood, but rather plastic, one could actually paint it after masking the logo which would allow for a much better looking repair.
Old Dec 29, 2009 | 01:19 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
i dont want the wood in my car, camaro is a sports car, wood is more luxury.
not even sure about the carbon fiber, but i wouldnt mind trying it
Old Dec 29, 2009 | 01:42 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
something like this!!!
not sure if i trust where i found it though, but in a deep dark red it would be amazing
http://www.wooddashkit.com
Old Dec 29, 2009 | 11:19 AM
ericjon262's Avatar
I think the carbon fiber might look good, personally, I really like the stock dash. have you considered a brushed aluminum type finish?
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Pilotrick50
Sep 2, 2015 12:48 PM
86IROC112
Aug 31, 2015 07:00 AM
Street Lethal
Aug 14, 2015 08:25 PM
